cylinder head dimensions
07-06-2010, 12:33 PM
good luck - around here they are very espensive
AE86 ex-daily |
07-12-2010, 08:03 AM
oldeskewltoy: I am not that surprised, I have heard of 38cc before and the 39cc is probably just a number that came from somewhere that kept on being handed down over time.
My website: S-86.com |
07-12-2010, 09:05 PM
Thanks people.
Maybe it is possible to measure a standard head as a reference for everyone. Perhaps a measurement of the flat between the two inner cylinders ? If the head has been skimmed the distance would be larger. Maybe ? An analogue brain in a digital World |
09-17-2010, 12:37 AM
one head - before 36cc chambers......
after 38+ cc chambers. The final volume of the chambers is still unknown. After the 3 angle is finished, (with each valve in its final location) I'll adjust the chambers accordingly. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
4AGE cylinder head plug removal | Ivan141 | 5 | 1,991 |
Brake advice - master cylinder | mannix20vt | 12 | 13,864 |
Correct connection brake master cylinder? | bozu | 5 | 7,156 |
Quick question - Brake Pad Dimensions | Lt86 | 2 | 5,252 |
06-07-2015 12:08 AM Last Post: jondee86 |
torque setting head cylinder bolts | izanagi | 1 | 4,847 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
