cylinder head.
05-07-2011, 06:10 AM
cylinder head.
You have an AE85, not AE86...
05-07-2011, 08:55 AM
cylinder head.
In the US an AE86 is SR5 SOHC and the AE88 is GTs I think Smile
[Image: AEU86 AE86 - cylinder head.]
05-07-2011, 12:09 PM
cylinder head.
Jep, there are 4AC AE86's, mine was one originally as well.
05-07-2011, 01:29 PM
cylinder head.
Correct, certain countries like Australia got ae86 with a 4ac, makes you wonder what th point of an ae85 was?
05-08-2011, 02:09 PM
cylinder head.
Its just a chassis code.. still sold as a corolla, its mostly us reading too much into it after being indoctrinated by InitialD Smile
05-08-2011, 04:42 PM
cylinder head.
Whilst you could fit a 16v 4AGE you'll need all the bits that go with it, ECU loom etc.
If you have drums on the rear chances are you won't have an LSD as LSD wouldn't come with this axle.
Again you can change to AE86 running gear, you just need to find all the parts so you will likely need engine, gearbox, axle etc, so replace the lot. Not sure if the props or not are different.
1985 Sprinter Trueno GT Apex
2013 GT86 Miltek Exhaust, Injen Induction.
05-08-2011, 06:18 PM
cylinder head.
AE85 uses 3AC
If it has a 4A in it(4AC, or 4AGEC, or 4AGE) it is an AE86. AE88(4AGE equipped) is part of the vin, but the chassis is still an AE86
rear brakes have nothing to do with chassis code
Dan -
05-08-2011, 10:03 PM
cylinder head.
Well according to the Toyota EPC Nort America never had the AE85 named frame - just AE86 in three models DX, SR5 and GTS
I guess your model code (that's the important thing) is AE86L-ESMXCA
which means a US SR5 model with 2 doors, 5 shift manual transmission and a 4AC engine
if the S in the code is a C it reffers to the 3 door model
all found in the EPC or here online http://www.toyodiy.com/parts/g_U_1985_TO...SMXCA.html
Wink
The model code is the most specific one and pending on that things like brakes, AC, servo, etc differ - that's also where the difference in the European versions is regarding the engine variations with different CR Pistons, emission add-ons and so forth.
AE86 ex-daily
  4AGE cylinder head plug removal Ivan141 5 2,369 09-30-2023 09:47 PM
  Brake advice - master cylinder mannix20vt 12 14,783 08-21-2017 03:21 PM
Last Post: Project D
  Correct connection brake master cylinder? bozu 5 7,601 07-26-2015 12:28 PM
Last Post: bozu
  torque setting head cylinder bolts izanagi 1 5,103 05-29-2015 01:23 AM
Last Post: oldeskewltoy
  Dimensions clutch master cylinder bozu 2 6,369 04-16-2015 07:11 AM
Last Post: bozu
