dash lights problem
02-03-2007, 10:11 PM
dash lights problem
Just shortcut it.
You can do this at the back of the rheostat or by shortcutting pins 1 and 9 in the plug on the diagram shown above by Banpei. I guess that plug must be somewhere close to the light switch (yes light switch not rheostat switch).
02-04-2007, 06:26 AM
dash lights problem
just a question. Have you checked your rear running lights? if they are out replace them... they may fix your dashlight problem. Thats what i did on my protege, integra, civic, and my father's ford ranger. The dash lights went out and i was like WTF m8. Then i noticed my rear running lights were out. Replaced them and fixed the problem.
02-04-2007, 08:04 PM
dash lights problem
rear lights work just fine
managed to sort half of the dash now, the rev counter lights up thats the important bit sorted
now jst need to sort the speedo out, its not the bulbs i replaced all of those
[Image: AEU86 AE86 - dash lights problem]
DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS
02-04-2007, 09:37 PM
dash lights problem
I some of the lights work it's probably not the rheostat, if that would fail none of the lights would work. I guess the rheostat works for the rev counter lights, right?
02-04-2007, 09:59 PM
dash lights problem
actually scratch that
checking it aty night when it is dark might be a better idea
all my dash lights now work Big Grin
02-05-2007, 10:16 AM
dash lights problem
LOL! Big Grin Big Grin
The dashlights are indeed a bit dim. Wink
02-05-2007, 08:15 PM
dash lights problem
banpei Wrote:LOL! Big Grin Big Grin
they just look dim in the picture
took with my phone, they are lovely and bright in person
03-25-2009, 05:11 PM
dash lights problem
Ivan141 Wrote:EE80 has it right on the money. Your rheostat (potentiometer whatever) is faulty, just fixed this on my car by taking the wire out of the connector and shorting it to the nearest groundwire I could find (on some un-used connector behind the dash cover). This way your backlights will work at full intensity, without adjustability. I'll be trying to fix mine once I put my spare switch in.
could you tell me which wire exactly you grounded..?? the rheostat on my switch is kaput...the casing is cracked and the contacts / springs cant do their job..
Id like to have a temporary solution until i get a new switch installed..
03-25-2009, 10:32 PM
dash lights problem
Cant really remember anymore....I'll try to look it up if i get the opportunity. Just moved so I'm very busy lately.
03-26-2009, 02:32 AM
dash lights problem
got sorted, read on another thread... short out pin numbers 1 and 9 and you get the lights to remain on constant...bypassing the rheostat function
  Digital Dash evfan42 190 262,372 05-03-2024 06:44 PM
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 8,133 12-19-2021 11:58 PM
Last Post: gh0st
  Dash Waning Lights pack 7 4,300 10-06-2021 01:00 PM
Last Post: pack
  Trueno Digital dash kph to mph Bojack 3 7,041 11-21-2018 12:27 AM
Last Post: kazi
  Custom Dash Cluster kazi 14 20,297 10-24-2017 09:05 PM
Last Post: kazi
