difference when installing OEM or Cusco LSD
09-22-2010, 07:02 PM
is there any difference when installing an OEM LSD or a Cusco one, like a different backlash on the CWP or another preload?
thanks guys
09-25-2010, 06:24 AM
None, except for their own bolts that hold the carrier together may be a different size & spec from the stock LSD, and they may want thread locker instead of tabs for the bolts that hold the crownwheel/ring gear onto the carrier.
09-27-2010, 02:39 AM
Cusco (& other aftermarket LSD's) requires red threadlocker for the stock bolts. As you can't use the stock 'lock plates' anymore.
Backlash/torque/etc is the same.
Fluid used should include friction modifiers for LSD's. I recommend Motul 90pa, from personal use of many types I tried. (Mobil 1, redline, amsoil, valvoline, etc.)
Andrew
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 21,760 05-01-2021 10:09 PM
  Axel anyway to tell the difference? MIGGZFSU 7 8,158 10-24-2017 08:48 PM
Last Post: MIGGZFSU
  Why Zenki and Kouki colour difference MIGGZFSU 10 19,934 04-23-2017 09:16 AM
Last Post: MIGGZFSU
  OEM LSD modification malejyetti 40 55,814 06-23-2016 12:34 PM
Last Post: pack
  Windshield difference d3nso 3 6,615 03-26-2016 02:21 AM
Last Post: fax0815
