Axel anyway to tell the difference?
10-23-2017, 04:09 PM
Hey guys
Anyway to tell the difference between zenki and kouki on the axel?
I did not get shafts or a pigs head with it
[Image: AEU86 AE86 - Axel anyway to tell the difference?]
Sent from my F3111 using Tapatalk
Signature removed due to large photobucket message
10-23-2017, 04:40 PM
Bu the halfshaft thikness! Smile
10-23-2017, 06:00 PM
(10-23-2017 04:40 PM)pack Wrote:  Bu the halfshaft thikness! Smile
this housing never came with the shafts or the pigs head. So now i must look for a matching set
10-23-2017, 06:04 PM
From outside they are all the same! I tought you had a spare one!
You can use it Smile
10-23-2017, 08:39 PM
Oooooo no sir, currently in the car is a S series
10-24-2017, 05:36 PM (This post was last modified: 10-24-2017 05:37 PM by oldeskewltoy.)
These are one set of measurements... I've seen others too. The key is anything under 24.5mm is zenki, anything over 24.9mm is kouki.
Dan -
10-24-2017, 06:25 PM
You should read my article!
http://www.aeu86.org/2014/09/25/ae86-the...-approach/
10-24-2017, 08:48 PM
(10-24-2017 06:25 PM)pack Wrote:  You should read my article!
that makes a lot of sense thanks bud
  Why Zenki and Kouki colour difference MIGGZFSU 10 22,766 04-23-2017 09:16 AM
Last Post: MIGGZFSU
  Windshield difference d3nso 3 7,674 03-26-2016 02:21 AM
Last Post: fax0815
  brake booster difference zenki(2 bolt)/kouki 4 bolt v ditn 1 5,367 03-22-2016 09:43 PM
Last Post: ditn
  A60 Carina rear axel, AE86 parts nyberrg 3 7,591 09-02-2015 09:21 PM
  4age 16v 1st and 2nd generation cams and not only difference Apsogos 3 8,646 09-16-2013 08:24 AM
Last Post: Apsogos
