Axel anyway to tell the difference?
10-23-2017, 04:09 PM
Hey guys
Anyway to tell the difference between zenki and kouki on the axel? I did not get shafts or a pigs head with it ![]() Sent from my F3111 using Tapatalk |
10-23-2017, 04:40 PM
Bu the halfshaft thikness!
10-23-2017, 06:00 PM
(10-23-2017 04:40 PM)pack Wrote: Bu the halfshaft thikness! this housing never came with the shafts or the pigs head. So now i must look for a matching set |
10-23-2017, 06:04 PM
From outside they are all the same! I tought you had a spare one!
You can use it ![]() |
10-23-2017, 08:39 PM
Oooooo no sir, currently in the car is a S series
10-24-2017, 05:36 PM
(This post was last modified: 10-24-2017 05:37 PM by oldeskewltoy.)
![]() These are one set of measurements... I've seen others too. The key is anything under 24.5mm is zenki, anything over 24.9mm is kouki. Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-24-2017, 06:25 PM
Axel anyway to tell the difference? | |||
10-24-2017, 08:48 PM
(10-24-2017 06:25 PM)pack Wrote: You should read my article! that makes a lot of sense thanks bud |
Why Zenki and Kouki colour difference | MIGGZFSU | 10 | 19,892 |
04-23-2017 09:16 AM Last Post: MIGGZFSU |
Windshield difference | d3nso | 3 | 6,606 |
03-26-2016 02:21 AM Last Post: fax0815 |
brake booster difference zenki(2 bolt)/kouki 4 bolt v | ditn | 1 | 4,507 |
03-22-2016 09:43 PM Last Post: ditn |
A60 Carina rear axel, AE86 parts | nyberrg | 3 | 6,539 |
09-02-2015 09:21 PM Last Post: banpei |
4age 16v 1st and 2nd generation cams and not only difference | Apsogos | 3 | 7,784 |
09-16-2013 08:24 AM Last Post: Apsogos |
