difference when installing OEM or Cusco LSD
09-22-2010, 07:02 PM
is there any difference when installing an OEM LSD or a Cusco one, like a different backlash on the CWP or another preload?
thanks guys |
09-25-2010, 06:24 AM
None, except for their own bolts that hold the carrier together may be a different size & spec from the stock LSD, and they may want thread locker instead of tabs for the bolts that hold the crownwheel/ring gear onto the carrier.
09-27-2010, 02:39 AM
Cusco (& other aftermarket LSD's) requires red threadlocker for the stock bolts. As you can't use the stock 'lock plates' anymore.
Backlash/torque/etc is the same. Fluid used should include friction modifiers for LSD's. I recommend Motul 90pa, from personal use of many types I tried. (Mobil 1, redline, amsoil, valvoline, etc.) Andrew |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 21,018 |
05-01-2021 10:09 PM Last Post: Ivan141 |
Axel anyway to tell the difference? | MIGGZFSU | 7 | 7,877 |
10-24-2017 08:48 PM Last Post: MIGGZFSU |
Why Zenki and Kouki colour difference | MIGGZFSU | 10 | 19,267 |
04-23-2017 09:16 AM Last Post: MIGGZFSU |
OEM LSD modification | malejyetti | 40 | 54,284 |
06-23-2016 12:34 PM Last Post: pack |
Windshield difference | d3nso | 3 | 6,450 |
03-26-2016 02:21 AM Last Post: fax0815 |
