differences in big port and small port oem cams
06-25-2010, 02:51 AM
just wondering is the duration and lift the same on both these engines?
06-25-2010, 08:52 AM
According to Club4AG, the big port cams are said to have a tiny bit more
lift (7.56 vs 7.1) and a fraction more duration (240 x 232). However, even though this swap is often recommended, I have never seen a post with figures to prove that there is any measurable gain. Where are the "Mythbusters" when you need them ![]() Cheers... jondee86 |
06-25-2010, 11:02 AM
Hi there , I tried this swap and dynoed the car before and after with no other changes ,(smallport) and there was no noticeable gains to be had , so swapped back to the originals .The figures may be different between the two types of camshaft but maybe the head differences prevent any gain ?
Your addiction to motorsport can only be cured by poverty !! |
06-25-2010, 12:12 PM
nzae86 Wrote:The figures may be different between the two types of camshaft but maybe Quite likely. Toyota will have optimised the cams for each engine. They would have tested many different profiles before they settled on the the one that best met their goals for the engine. Meeting emission standards, and having an engine that worked well with an auto trans, would have almost certainly been part of the design brief for the smallport. Because, having lost the "sporty" RWD platform, there was no longer any need for a "sporty" free-revving engine when the smallport was being developed. So yeah, hardly surprising that there is no gain when swapping cams. Bit like when I put GZE cam covers on my smallport... ![]() Cheers... jondee86 |
06-25-2010, 01:36 PM
I had bigport cams in my car, I havent't dynoed it, so I can't say any results, only my butt dyno showed something
07-03-2010, 01:52 PM
I have heard reports of 3kw, I can't personally verify it though
Big wheel problems | gh0st | 16 | 10,253 |
Clutch differences LUK vs Exedy | r.ave | 2 | 5,904 |
05-27-2021 09:30 AM Last Post: r.ave |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 95,183 |
05-05-2019 04:03 AM Last Post: Rocker100 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 8,278 |
Shim size for AM cams | kazi | 4 | 5,880 |
