Clutch differences LUK vs Exedy
05-26-2021, 07:50 PM
Hi All,
I have an issue with a clutch kit. As my gearbox is removed as it had some issues i wanted to renew the clutch while everything was off. As i'm not doing trackdays with this car i decided to go for a normal clutch replacement kit by LUK. When comparing the 3 components of the kit with what came of the car we saw that the bearing was much different. The one whith the LUK kit was only 2.4cm tall , the old one (with exedy set) was 4.6cm tall. See picture ![]() When looking up the numbers on the items, I can't seem to find a picture of a similar bearing. As for the reference on the old set Pressuregroup: Exedy 8G18A TYC553 Clutchplate Exedy TYD008UF 8G06A Bearing: KOYO RCTS4067A Can somebody help me clearing this up? Also, i assume when installng the new smaller bearing there will be some difference in the pedal I guess, but what? Thanks all |
05-26-2021, 09:59 PM
That's a FWD bearing. Not compatible with the RWD gearbox.
By the way, I can guarantee that NO clutch kit (even a "RWD" kit) comes with the hub (only the bearing; the bottom part of your old setup) |
05-27-2021, 09:30 AM
(05-26-2021 09:59 PM)Project D Wrote: That's a FWD bearing. Not compatible with the RWD gearbox.Indeed, the number is Ina F-572637.01 and that's for a fwd..idiots (05-26-2021 09:59 PM)Project D Wrote: By the way, I can guarantee that NO clutch kit (even a "RWD" kit) comes with the hub (only the bearing; the bottom part of your old setup) Why is this? |
Exedy Hyper Single Clutch Kit Question | mister86 | 2 | 3,755 |
03-13-2020 06:06 PM Last Post: twincamdill |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 90,592 |
05-05-2019 04:03 AM Last Post: Rocker100 |
20v exedy clutch | XandyX | 3 | 5,911 |
10-16-2018 02:40 PM Last Post: pack |
Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, | dsrturbo | 2 | 6,068 |
07-28-2011 10:51 AM Last Post: Bean |
differences in big port and small port oem cams | jonny514mcl | 6 | 7,723 |
07-03-2010 01:52 PM Last Post: Sam-Q |
