Clutch differences LUK vs Exedy
05-26-2021, 07:50 PM
Hi All,
I have an issue with a clutch kit.
As my gearbox is removed as it had some issues i wanted to renew the clutch while everything was off.
As i'm not doing trackdays with this car i decided to go for a normal clutch replacement kit by LUK.
When comparing the 3 components of the kit with what came of the car we saw that the bearing was much different.
The one whith the LUK kit was only 2.4cm tall , the old one (with exedy set) was 4.6cm tall.
See picture
[Image: AEU86 AE86 - Clutch differences LUK vs Exedy]IMG_0493[1] by Robert Ave
When looking up the numbers on the items, I can't seem to find a picture of a similar bearing.
As for the reference on the old set
Pressuregroup: Exedy 8G18A TYC553
Clutchplate Exedy TYD008UF 8G06A
Bearing: KOYO RCTS4067A
Can somebody help me clearing this up?
Also, i assume when installng the new smaller bearing there will be some difference in the pedal I guess, but what?
Thanks all
05-26-2021, 09:59 PM
That's a FWD bearing. Not compatible with the RWD gearbox.
By the way, I can guarantee that NO clutch kit (even a "RWD" kit) comes with the hub (only the bearing; the bottom part of your old setup)
05-27-2021, 09:30 AM
(05-26-2021 09:59 PM)Project D Wrote:  That's a FWD bearing. Not compatible with the RWD gearbox.
Indeed, the number is Ina F-572637.01 and that's for a fwd..idiots
(05-26-2021 09:59 PM)Project D Wrote:  By the way, I can guarantee that NO clutch kit (even a "RWD" kit) comes with the hub (only the bearing; the bottom part of your old setup)
Why is this?
  Exedy Hyper Single Clutch Kit Question mister86 2 3,547 03-13-2020 06:06 PM
Last Post: twincamdill
  4AGE block differences explained (incl. some eyecandy) Bean 46 86,887 05-05-2019 04:03 AM
Last Post: Rocker100
  20v exedy clutch XandyX 3 5,642 10-16-2018 02:40 PM
Last Post: pack
  Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, dsrturbo 2 5,842 07-28-2011 10:51 AM
  differences in big port and small port oem cams jonny514mcl 6 7,245 07-03-2010 01:52 PM
Last Post: Sam-Q
