digital cluster on 4agze coil packs??
07-07-2011, 01:53 AM
ok so am running the ae101 4agze coil packs on my 20v and i have a tach adapter so it can read it correctly to my cluster...but somehow it still doesnt read it right and was wondering if anyone had any idea of what i could do so my tach can read the rpms correctly
i have a digital cluster on my ae86 and i have this tach apater http://www.summitracing.com/parts/ATM-9117/?rtype=10 now supposedly it should work since i had the the wiring profesionally done but still fails to read correctly the tach i also saw on club4ag that if i change the resistors in the cluster it will fix the problem but i have a digital cluster so the board inside is a little more complex so i cant change what i need to..... so i dont know what im lookin for any help would be great |
07-07-2011, 08:51 PM
You could just have built a tach signal booster and connect it to the ECU output, which I am assuming is present on the 20V ecu.
I build and sell those myself to anyone who's interested, but it's not too hard to do yourself. FABRICA MI DIEM, PVNC! |
07-09-2011, 12:49 AM
o ok sure am down to make one..
i have aftermarket ecu though stinger...will that be a problem? |
07-10-2011, 01:24 AM
No problem, all you need to know is the voltage level of the output signal (5 or 12 volts?).
I am assuming the digital cluster takes it's signal from the same source as a regular tach, in which case a booster should work. FABRICA MI DIEM, PVNC! |
03-21-2012, 09:55 AM
i know this is old but yes i need an output of 12v and input 5v
how would i go in making it? do i use a relay? is their any relay on the ae86 that i could use to build this? i saw this http://www.toymods.org.au/forums/tech-co...oster.html also how much would you charge? shipped the USA? |
03-21-2012, 12:54 PM
I'll have a look, I just use small PCB relays myself to keep form factor small (and I happen to have more of them than I know what to do with).
I use the exact same design as the one on toymods, I just make sure to calculate the resistors for the desired input voltage. Output is not exactly 12v, the coil is used to create spikes which the tacho expects to receive. FABRICA MI DIEM, PVNC! |
| Digital Dash | evfan42 | 190 | 301,193 |
05-03-2024 06:44 PM Last Post: banpei |
| EUDM gauge cluster | banpei | 22 | 9,605 |
08-15-2023 10:48 PM Last Post: banpei |
| EUDM cluster revelations | banpei | 1 | 2,331 |
06-23-2023 09:11 AM Last Post: r.ave |
| Digital speedometer on stock dashboard | FanIsHere | 0 | 2,435 |
| Smallport coil | totta Crolla | 2 | 2,894 |
08-12-2022 11:03 AM Last Post: totta Crolla |
