distributor prob
12-15-2010, 08:20 PM
distributor prob
Hi guys my ae86 distributor started leaking and since i had a spare distributor off an AW11 i decided to put it on.
I installed the AW11 distributor and now the car runs crappy,
Before install i set TDC on the engine and made sure the rotor arm is at the 1 position (on the cap)
Once installed it struggled to start so I twist the distributor all the way clockwise and it will run but really not well,
if i twist it anti clockwise the engine will struggle and slowly cut off.
Im using aw11 cap and leads aswell
Car was running fine with the original distributor
I dont know what i missed
any help appreciated
thx, Alex
12-15-2010, 08:26 PM
distributor prob
Until someone with better knowledge answer..
Are both cars MAP/AFM ? Maybe you mixed it up ?
Checked if all leads/sparks are firing ?
12-15-2010, 08:50 PM
distributor prob
I dont know if i mixed up as i searched around and ppl has used aw11 distributor on ae86's with no probs
will check the leads tmr as its dark now, i used the aw11 ones, but will try the 86 leads tmr
12-15-2010, 10:56 PM
distributor prob
If I´m right the AFM dizzy has a different plug for rpm signal but not sure...
Swap over the finger/ cap and leads from the AE dizzy if its still there, check the diagnosis codes, mayby your engine can tell you whats wrong Smile
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
12-15-2010, 11:04 PM
distributor prob
the plug from the aw11 dizzy (yellow plug) plugged straight into the loom no probs Smile and looks the same as the 86 one
I will check/use the leads and rotor arm from the 86 dizzy as i cant use the ae86 cap as the holes wont line up
12-15-2010, 11:52 PM
distributor prob
It sounds like the distributor is a tooth out.......
12-16-2010, 12:33 AM
distributor prob
damn lol
will re-install the dizzy again once i check lead and arm
  16v distributor hole plug harkes 8 10,251 10-12-2016 11:13 AM
Last Post: harkes
  Changing distributor when carb 4age izanagi 14 17,255 07-04-2016 03:27 PM
Last Post: Uzelac
  Distributor position and cranking pack 13 20,859 07-01-2013 11:08 PM
Last Post: pack
  weak spark. new distributor? please help. stasis_dc5 3 7,722 04-11-2011 12:35 AM
Last Post: fax0815
  4age distributor, what's similiar ? Uzelac 3 5,773 11-11-2010 01:25 PM
Last Post: Uzelac
