eliminating egr
05-15-2008, 04:54 PM
eliminating egr
I've been looking around and I can't find a post on how to eliminate the egr on the corolla.
I'm also new to the whole corolla scene any help appreciated |
05-17-2008, 05:38 PM
eliminating egr
well you have to take off all the egr stuff and plug/cap all the holes. ill try to get pics for you later.
te72 wagon ae86 levin coupe project ![]() |
05-18-2008, 10:32 AM
eliminating egr
Are there workaround solution like removing some vac tube etc ?
05-20-2008, 05:17 AM
eliminating egr
theres a bolt that goes to the header that needs to be removed and capped off.
if you want it to look like its still functioning then its tricky. but ive done it before. for the port that goes to the intake manifold make a cover in the shape of the gasket. seal it with silicone, bolt it back and let dry. now for the exhaust manifold. unbolt the big bolt and have the holes welded shut. that will prevent the exhaust fumes to go to the egr location. then bolt it back into place, dont forget the thin washer/gasket looking things. and voala you still have the egr on and not functioning. robbing HP and keeping that hot air out of your intake. also plug off the vacuum plugs on the intake system. i didnt have my camera when i did that set up. and i havent had a chance to get pics of the set up where i eliminate the whole system. the car i did it on is at the body shop. te72 wagon ae86 levin coupe project ![]() |
05-21-2008, 06:25 AM
eliminating egr
Elminating the EGR doesn't increase any power at all!
05-21-2008, 04:55 PM
eliminating egr
hmm. if it doesnt increase HP, then why does it run better w/out the EGR?
is it that there is no hot air going back into the intake manifold? i felt a bit of a difference when i did it. its no major HP gain i know, but it ran allot better. te72 wagon ae86 levin coupe project ![]() |
06-17-2008, 01:13 AM
eliminating egr
The suspicion is that people want to keep their intake tract cleaner longer.
EGR valve and emission stuff | CoolinAE86 | 7 | 6,461 |
01-22-2009 01:21 AM Last Post: Project D |
EGR disconection? | Allexz | 7 | 6,609 |
01-06-2008 09:41 PM Last Post: rooty |
4AGE EGR system maintenance? | Red | 1 | 3,304 |
12-31-2006 11:26 PM Last Post: Red |
EGR keep it or remove it? | max_ae86 | 7 | 7,738 |
11-19-2005 09:31 AM Last Post: alex16 |
