revison steering rack possible?
10-07-2009, 05:31 PM
I have play on my steering rack, and want to eliminate it.
can it be done by just a revision? or do I have to replace it totally? Regards, Roel Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
10-07-2009, 05:50 PM
Try tightening it. I had my rack a little loose, tightening the rack bolt a little and replacing bottom universal joint between shaft and rack solved the problem.
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,673 |
Quaife quick rack | totta Crolla | 19 | 20,700 |
03-03-2018 03:32 PM Last Post: Deuce Cam |
weird gearbox part2(possible trd set a) | ditn | 6 | 6,923 |
01-31-2016 08:01 PM Last Post: totta Crolla |
Why Manual Steering Rack ?? Power Steering Removal | juantonwan | 26 | 42,795 |
20v block with 16v head and internals possible? | ditn | 3 | 6,942 |
08-12-2014 09:19 PM Last Post: ditn |
