fitting rear window
03-07-2009, 03:59 PM
fitting rear window
does any one know what the stuff is i need to fix/adhere the rear window in a boot?
thanks My Hachi Roku |
03-07-2009, 04:13 PM
fitting rear window
None, the rubber seals it,
you will need mig wire or some thing to pull the window in, you should have a big rear rubber? An 86 is for Life, not just for Christmas |
03-07-2009, 09:31 PM
fitting rear window
its actually a FRP CBY boot with Lexan glass. reading the manual says that i needs a adhesive to fix the weather strip to the car and glass... i dont want the glass popping out when driving along...
... you sure i dont need it? My Hachi Roku |
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 4,160 |
01-07-2024 11:36 AM Last Post: CCB |
Fitting Fibreglass Kouki Lip? | chrisae86 | 3 | 2,100 |
02-25-2022 08:14 PM Last Post: chrisae86 |
window winder mechanism | kazi | 4 | 4,954 |
05-23-2018 11:00 PM Last Post: kazi |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,688 |
05-30-2017 10:50 AM Last Post: bozu |
Removing front window trim | zenki | 7 | 12,360 |
09-07-2014 08:36 PM Last Post: Ivan141 |
