fitting rear window
03-07-2009, 03:59 PM
fitting rear window
does any one know what the stuff is i need to fix/adhere the rear window in a boot?
thanks
My Hachi Roku
03-07-2009, 04:13 PM
fitting rear window
None, the rubber seals it,
you will need mig wire or some thing to pull the window in, you should have a big rear rubber?
03-07-2009, 09:31 PM
fitting rear window
its actually a FRP CBY boot with Lexan glass. reading the manual says that i needs a adhesive to fix the weather strip to the car and glass... i dont want the glass popping out when driving along...
... you sure i dont need it?
My Hachi Roku
  Fitting Air Con (No PS) to LHD AE86 pack 7 4,334 01-07-2024 11:36 AM
Last Post: CCB
  Fitting Fibreglass Kouki Lip? chrisae86 3 2,173 02-25-2022 08:14 PM
Last Post: chrisae86
  window winder mechanism kazi 4 5,050 05-23-2018 11:00 PM
Last Post: kazi
  Fitting driftworks CS2 coilovers bozu 2 4,802 05-30-2017 10:50 AM
Last Post: bozu
  Removing front window trim zenki 7 12,535 09-07-2014 08:36 PM
