fuel regulator do i need one
10-10-2007, 01:36 PM
i recenlty did a twinconverson but running a weber carb on it ..i connected a filter from the tank and from there the fuel pump and ran the pipe direct to the carb do i need a fuel aswell regulator
10-10-2007, 02:43 PM
Depends on the type of fuel pump and the fuel pressure that is being produced. Supposedly Webers have a fuel-pressure sweetspot that they like running on (very low if I remember correctly) but a google search will show up results without problems.
If the fuel pressure is low enough, then you can just hook the carb up. If its to high, you either need to switch pumps (easy) or run a FPR and a fuel return line (irritating work). Just hook up a fuel pressure meter to the rail and measure..always handy to have around when diagnosing problems with the car anyway. A wheel to steer the front of the car A pedal to steer the rear |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 22,598 |
4AGE Fuel Regulator | Alex170984 | 6 | 11,003 |
02-24-2016 05:59 PM Last Post: totta Crolla |
adjustable fuel pressure regulator on stock 4AGE | fax0815 | 8 | 20,152 |
01-07-2012 02:37 AM Last Post: oldeskewltoy |
Fuel pressure regulator? | heshan | 18 | 18,212 |
05-10-2010 04:17 PM Last Post: heshan |
Fuel Pressure Regulator needed for a AE86 | heshan | 2 | 4,246 |
02-26-2009 10:35 PM Last Post: totta Crolla |
