goodridge SS brake lines fitting doubts
03-30-2014, 03:10 PM
i bought the 6 line set from goodridge assuming that it was 5 lines for the brake system and 1 for the clutch.I was wrong and now im missing the line that connects the rear axle to the chassis, but that is of later concern.
The rear lines seem to fit, although i am not a big fan of the double chamfered connectors of the ss lines.In my opinion they should be an exact copy of the oem ones.This option is probably cheaper for goodrigde.
The front ones also seem to fit, my only big concern is that the connection where the 2 goodridge cables connect with each other are chamfered the same way.Im not an brake line expert but my logical thought tells me this will never seal, and if they seal they wil barely.
Am i missing something, is there something wrong with this set, am i putting them together in a wrong way?If this is meant to be this way i have more faith in the original brake lines.I also have a HEL set lying around here, fittings don't look like original as well.
Real men race downhill
03-30-2014, 05:32 PM
i have them on my 1986 rolla. Works fine but I also had the one from the rear axle to the chassis. The front should seal off but the only way to know is to try it Smile
03-30-2014, 09:51 PM
Have hade the same problem before with a goodridge AE86 set, were you connect the 2 front line together. Eended up machining the the one brakeline that screws in to a 60° taper (female) to make sure it seals. Never had any problems.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
03-30-2014, 10:19 PM
fax0815 Wrote:Have hade the same problem before with a goodridge AE86 set, were you connect the 2 front line together. Eended up machining the the one brakeline that screws in to a 60° taper (female) to make sure it seals. Never had any problems.
that sounds like an assuring option, i can let them machined at my work.still i think it is a very odd construction by goodridge to produce them this way.
03-30-2014, 10:40 PM
Yeah they shouldn´t be selling that, especially if you buy them from a brand lke goodrige...
03-31-2014, 04:29 PM
is there a good and afordable alternative for goodrige?
Gtsi-R
"Trust me, I was an engineer"
04-03-2014, 12:52 AM
That kit looks like it is for ae82/fwd. The ae86 one ends in 7p. Not 6p.
Buy the late model/kouki 5 line set. STY0451-5P, that way no split front lines.
Andrew
04-03-2014, 07:55 AM
assassin10000 Wrote:That kit looks like it is for ae82/fwd. The ae86 one ends in 7p. Not 6p.
Andrew
I remeber that now, the set were I drilled the taper, was sold as AE86, but had AE82 on packaging. Like I said, all I had to do was the taper, the rest fitted perfect in an AE86.
04-03-2014, 11:08 PM
the package clearly says ae86 right?
i am having some mail contact with goodridge now but it looks like they are evading clear answers.been sending mails up and down for a few days.
Im gonna get this one tapered like fax says, but i want goodridge to admit that what they manufactured is wrong.
How would this set fit on an ae82? the point were the 2 front brake lines meet doesn't change right? so you would still have a problem.
Buying another set? if i buy something from a renowned brand and it is suited for the car it was designed for it should just fit, or else it should be fixed.
04-04-2014, 09:07 AM
Goodridge have a shop in Delft (or at least they had many moons ago when I had my lines made). They should be able to straighten things out for you, but perhaps you're already in contact with them.
  Fitting Air Con (No PS) to LHD AE86 pack 7 7,113 01-07-2024 11:36 AM
Last Post: CCB
  Fitting Fibreglass Kouki Lip? chrisae86 3 3,642 02-25-2022 08:14 PM
Last Post: chrisae86
  Doubts about specific AE86 parts Patrick Ross 19 18,729 02-24-2019 12:28 PM
Last Post: Patrick Ross
  Fitting driftworks CS2 coilovers bozu 2 6,106 05-30-2017 10:50 AM
Last Post: bozu
  braided brake lines izanagi 12 15,020 11-09-2015 01:24 PM
Last Post: The Doctor
