greetings from cyprus
08-09-2006, 01:46 PM
nmwisima! read carefully "no problems with coversion"
my opinion too about this gauges, it looks comic but its not my car, damn http://www.86ers.org All the hachies that Daytona can only dream about. |
08-09-2006, 01:56 PM
the reason i have those gauges is beacause at night the dashboard does not light up most of the time, so i needed something else to show me the rpm and the temp...the volts and the vaccum are for fun and i got them for free :wink:
TUNING IS NOT A CRIME |
08-09-2006, 10:14 PM
Ah ok! Just ask Ivan about the fix for it..his does it as well and I believe its a simple problem with a connector..It looks like a Swiss kuckoo clock shop interior like this
ae86 cyprus Wrote:yes of course! since 1960 when cyprus was an english colony, we drive rhd cars and drive in the left, just like uk...why? dont u like it?Thanks, I didn't know that. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
08-10-2006, 08:03 AM
NoHachi Wrote:Ah ok! Just ask Ivan about the fix for it..his does it as well and I believe its a simple problem with a connector..It looks like a Swiss kuckoo clock shop interior like this Ehm... I have tried about 5 times now and I still havent figured out what the problem is with those dashboard lights. it's either the light switch or a bad connection/broken wire from the switch to the dashboard. Silly 80's jap electronics are really awkward to work with...they switch the lights to ground instead of to 12v, gets confusing sometimes. FABRICA MI DIEM, PVNC! |
08-10-2006, 01:51 PM
the dial for the lights uses a resistor, and thats the real problem! you need to punch it several times in order to get the dial light to work...the least i could do was to put the other ones on...
08-10-2006, 02:37 PM
I used to do that too...but after a while it just got worse and worse until it wouldnt light up anymore... mine seemed to work if i wiggled the wires at the back of the switch a certain way so I suspect a wire break. Measurements on the switch didnt indicate it was broken.
08-10-2006, 03:38 PM
unfoertunatly..
Greetings Hachi Roku Tomodachi! | RolanTHUNDER | 4 | 2,224 |
11-30-2022 03:56 PM Last Post: Power_uP |
Greetings from Germany | MyCrazyGarage | 2 | 2,522 |
07-04-2022 11:29 PM Last Post: decryphe |
Greetings from Croatia | nicfr | 1 | 4,323 |
05-22-2015 10:30 PM Last Post: banpei |
Greetings from Croatia :D | VanjaIvanusic | 4 | 6,762 |
07-01-2013 01:46 AM Last Post: Anso |
Hello Greetings from EL Salvador | darkjedi | 4 | 5,467 |
09-17-2012 09:35 PM Last Post: superli |
