greetings from cyprus
08-09-2006, 01:46 PM
nmwisima! read carefully "no problems with coversion" Cool Wave
my opinion too about this gauges, it looks comic but its not my car, damn Evil
http://www.86ers.org
08-09-2006, 01:56 PM
the reason i have those gauges is beacause at night the dashboard does not light up most of the time, so i needed something else to show me the rpm and the temp...the volts and the vaccum are for fun and i got them for free :wink:
TUNING IS NOT A CRIME
08-09-2006, 10:14 PM
Ah ok! Just ask Ivan about the fix for it..his does it as well and I believe its a simple problem with a connector..It looks like a Swiss kuckoo clock shop interior like this Smile
ae86 cyprus Wrote:yes of course! since 1960 when cyprus was an english colony, we drive rhd cars and drive in the left, just like uk...why? dont u like it? Big Grin
Thanks, I didn't know that. Blush
[Image: AEU86 AE86 - greetings from cyprus]
08-10-2006, 08:03 AM
NoHachi Wrote:Ah ok! Just ask Ivan about the fix for it..his does it as well and I believe its a simple problem with a connector..It looks like a Swiss kuckoo clock shop interior like this Smile
Ehm... I have tried about 5 times now and I still havent figured out what the problem is with those dashboard lights. it's either the light switch or a bad connection/broken wire from the switch to the dashboard.
Silly 80's jap electronics are really awkward to work with...they switch the lights to ground instead of to 12v, gets confusing sometimes.
08-10-2006, 01:51 PM
the dial for the lights uses a resistor, and thats the real problem! you need to punch it several times in order to get the dial light to work...the least i could do was to put the other ones on...
08-10-2006, 02:37 PM
I used to do that too...but after a while it just got worse and worse until it wouldnt light up anymore... mine seemed to work if i wiggled the wires at the back of the switch a certain way so I suspect a wire break. Measurements on the switch didnt indicate it was broken.
08-10-2006, 03:38 PM
unfoertunatly.. Sad
  Greetings Hachi Roku Tomodachi! RolanTHUNDER 4 2,154 11-30-2022 03:56 PM
Last Post: Power_uP
Big Grin Greetings from Germany MyCrazyGarage 2 2,478 07-04-2022 11:29 PM
Last Post: decryphe
  Greetings from Croatia nicfr 1 4,279 05-22-2015 10:30 PM
  Greetings from Croatia :D VanjaIvanusic 4 6,709 07-01-2013 01:46 AM
Last Post: Anso
  Hello Greetings from EL Salvador darkjedi 4 5,428 09-17-2012 09:35 PM
Last Post: superli
