headlight question
12-20-2010, 01:14 AM
headlight question
hi, i have an issue with my trueno headlamps.
they turn on and pop up all ok, but they wont stay in the up position with the lights off.
Is it possibly to make a d.i.y switch like for 'sleepy eye conversions' that i can use to keep the lights up and have them off?
Ive looked at the wiing diagrams but im not electricaly minded so im un-sure witch wires to use..?
Help please Thumbs up!
[Image: AEU86 AE86 - headlight question]
less traction..more action
12-23-2010, 03:25 AM
headlight question
ok so ive been thinking more about this, and think that a toggle switch to kill the power to the headlamps in dipped mode would be the answer... Wave
12-23-2010, 11:01 PM
headlight question
cfly86 Wrote:hi, i have an issue with my trueno headlamps.
The light switch should have a setting for raising the lights without turning them on. If that setting is unavailable on your switch your switch probably has been replaced by a Levin switch.
If it is available it will probably be either faulty or your popup-relay logic box is f#cked. (can't come up with the name)
12-24-2010, 12:19 AM
headlight question
there is an extra setting on the switch but when you set the switch to that point, the lights turn off and the lamps start to flap up and down out of sync...so its possible that something is fecked....
Do you think that a switch inline that would kill the power to the lights when activated and then keeping the lights in the open position and off at the flick of a switch...
  AE86 Headlight + wiper wiring (levin) bozu 11 15,971 09-19-2017 02:06 PM
  Trueno headlight help kazi 9 12,580 04-20-2017 09:37 AM
Last Post: kazi
  TRUENO - LHD headlight solutions pack 11 13,737 09-21-2016 10:29 AM
Last Post: pack
  Peculiar headlight issue - main beam Jezza_hr 3 5,800 10-04-2015 09:25 PM
Last Post: Jezza_hr
  LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays? Rascal21 11 14,729 07-07-2014 09:16 AM
