heat on my head covers
10-16-2007, 11:06 AM
not sure whats up with this
my cyclinder head coversheatsup like hot not sure what it is i dont have heat covers on my exshaust manifold could this be what causing my engine to heat up check raditor to see any problem but no water lost and my fan goes on and when i drive my heat temp is not near to half or sometimes in the center also checked oil .motor norm on oil any ideas i can look at ... |
10-16-2007, 01:08 PM
And the problem is? Engines just get hot..them explosions be going on inside them .
![]() Seriously though, if you're not having any problems, than what exactly are you asking ![]() A wheel to steer the front of the car A pedal to steer the rear |
10-16-2007, 01:23 PM
but it tend to get very hot like hot hot ..i was told its not suppose to do this ,,,,i no its sound dumb,,,but just wanna be sure
10-16-2007, 01:33 PM
Max_toy Wrote:but it tend to get very hot like hot hot ..i was told its not suppose to do this ,,,,i no its sound dumb,,,but just wanna be sure The engine isn't overheating on full throttle ?? 4AGE is generating a looot of heat for NA... and just a little glitch in your cooling and a lot of problems (head gasket and the stuff)... and it's 20+ years old so glitches do happen a lot ![]() There are some troublesome pipes for cooling system that get messed up, or losing pressure in cooling system that are almost impossible to see but it's enough to get into overheating troubles (like me and mrgud ![]() Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
10-16-2007, 03:33 PM
When I first got the Ae86 I also thought that it was overheating.
But the temp gauge never went past half of the scale. (mostly on 1/4th of the scale) On rainy days you can even see the raindrops evaporate on the bonnet/hood. A friend of mine was driving with me side to side and thought that my engine was overheating aswell...but that's just normal I guess...haha. |
11-22-2007, 09:05 AM
Check that your thermostat is not stuck closed. I'm reasonably sure that
the temperature sensor is on the downstream side of the thermostat. So if the thermostat is stuck closed, very little hot water reaches the sensor. This means it will still read cool when the engine is hot ![]() It also means that the engine will get hot as there is no water circulating thru the radiator. Does the top hose get hot ?? Does the engine blow steam out the radiator overflow ?? Is the water pump belt still there ?? Is your cooling water the colour of rust ?? Does your chewing gum lose its flavour on the bedpost overnight ?? :-P Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
4AGE Heat Shielding Intake Gasket | asyrigos | 11 | 24,339 |
04-01-2013 10:58 AM Last Post: asyrigos |
My new rebuilded denso starter (Heat soaked?) | Apsogos | 8 | 8,098 |
10-01-2012 07:43 PM Last Post: Apsogos |
AE86 heat unit panel with buttons and sliders | Okami | 6 | 10,696 |
09-09-2012 04:09 PM Last Post: Okami |
Remove paint from rocker covers | xrgeorg | 4 | 6,155 |
08-19-2011 03:05 AM Last Post: Lewy |
Heat... I want some heat! | amigaguy | 8 | 10,154 |
09-29-2009 05:44 PM Last Post: -Mister2- |
