highest lift and duration possible for stock ecu
02-19-2009, 02:31 AM
tolisspi Wrote:Good numbers. So 130 hp crankshaft
With stock ecu? Idle?
I'm guessing a bit closer to 135. It is rwd drivetrain loss....
Runs on a stock ECU idles at 850(does need to be adjusted about 1/8 turn for every 15-20 f degrees of change) It passes Oregon emissions sniffer too
Dan -
02-19-2009, 10:06 AM
what do you mean?
so is it a good combo of cams for a stock ecu?
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - highest lift and duration p... stock ecu]
02-19-2009, 06:35 PM
what do you mean?
I believe it is a good combo for a stock afm ecu... I have no exp with MAP ecu based cars.
What do I mean? As temps rise... my cars idle will change. As the seasons pass, I find I have to make minor idle adjustments. As winter moves to spring, the idle screw needs to be opened up(raised idle). As the cool weather approaches after a warm summer, the idle needs to be gradually turned in(lowered idle)
If I leave it at winter settings during the summer, the car will idle at about 500 rpm and want to stall. If I leave it set on summer settings, the idle in the winter would go up to about 1200 rpm. A minor adjustment during the seasonal change allows her to run just fine
Dan -
02-20-2009, 09:29 AM
very interesting info! Thumbs up!
02-20-2009, 09:36 AM
Indeed :wink:
02-20-2009, 10:57 AM
tolisspi Wrote:very interesting info! Thumbs up!
That's interesting!
Tolis,i think it's time to change your camshafts.. Thumbs up!
Oχι,δεν το πουλαω...
02-20-2009, 11:12 AM
You ae bad boy Angry
you want my cams Angry
im jocking
  Digital speedometer on stock dashboard FanIsHere 0 1,352 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,739 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,308 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,540 03-24-2019 04:10 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,815 02-20-2016 11:48 AM
