how do i convert the digital dash?
10-16-2006, 11:32 PM
i have a japanese toyota tureno.does anyone know how i convert the dash to display the speed in mph,rather than kph?
it is a digital dash.im having the rust on the car fixed now,will post some pics very soon! nice site btw, regards.................. ![]() |
10-16-2006, 11:39 PM
Is it me, or is it some sort of new style to start calling trueno's tureno?
![]() You do know tureno was made up by some guy when they made initial D because they weren't alowed to use the trueno brand name right? Note the carpet in your picture ![]() As for your question, no idea how to do this conversion but I know there are little gearing units that can be bought that you put on your speedo cables that are supposed to do this. They work with the analogue dashes, not sure if they work for digital dashes but I assume they should work... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-16-2006, 11:58 PM
thanks for th info!
im aware of the gearing mech. but its just a simple programme to do it.it must read kph/mph to pass the road test here in northern ireland. anyone else know? |
10-17-2006, 12:02 AM
is there not a boy in the autotrader n yellow pages the work at them
10-18-2006, 12:09 AM
you'll need a digital fueltank sender (part# 83320-19725),
replace the analog oil pressure sensor with a oil pressure switch (one of a EP71,82,91/SW20/AE92/ST16x will do. Or any toyota without pressure gauge, only oil pressure light switch) |
10-18-2006, 09:11 AM
Calavera Wrote:you'll need a digital fueltank sender (part# 83320-19725),He's not going to convert the whole gauge from analogue to digital, just convert the reading on the speedometer from kph to mph. ![]() You did a conversion as well, anything on how to change the readings? ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
10-18-2006, 10:13 AM
That could be an tricky one, with it being digital & all, the key might lie with the celica-supra digi set-up
11-07-2006, 01:45 AM
Bump for an old thread, someone help Fishlegs out, nobody with an answer?
(also moving this to tech) Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
11-07-2006, 01:54 AM
Can't seem to find anything noteworthy on club4ag about it
![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
11-07-2006, 09:35 AM
Fishlegs i might say something stupid but:
Why don't you try to find an analogue panel from a friend or so and place it just to pass the test and then put yours again in its place. I don't know if the cables and plugs fit the analogue panel. Cheers ![]() Toyota Corolla KE30 + Toyota Corolla AE86 |
Digital Dash | evfan42 | 190 | 270,705 |
05-03-2024 06:44 PM Last Post: banpei |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,617 |
Can you convert your 86 back too the original state? | gh0st | 7 | 3,285 |
Dash Waning Lights | pack | 7 | 4,762 |
10-06-2021 01:00 PM Last Post: pack |
Trueno Digital dash kph to mph | Bojack | 3 | 7,348 |
11-21-2018 12:27 AM Last Post: kazi |
