how to add power to AE86
11-26-2012, 08:07 PM
[list:d22a5402d9]cheap = good cams, headgasket, home made exhaust, MS-I v2.2 ~600€ if you shop around even less & lots of work (but that's probably a no go as you wouldn't need to ask the question in the first place)
future proof = rebuild + the sky is the limit.[/list:u:d22a5402d9] for a more elaborate answer we/I would need to know what you intend to use the car for? In most cases the money is better spent on bushings etc than the engine. AE86 ex-daily |
11-26-2012, 08:46 PM
Maybe it is more about how these different engines make their power ?
A big port with 272 cams is likely to come close to a blacktop 20v for top-end power but the blacktop with vvt will be much better low down and it will probably make more torque everywhere. An analogue brain in a digital World |
11-26-2012, 09:15 PM
as i read all this I think i'm better of with an s2000 (f20c) swap? =)
11-26-2012, 09:18 PM
good dampers and springs
good bushings good oem brakes that should be your first update ![]() lots of fun with a 4AGE on track/street |
11-26-2012, 09:25 PM
Just put turbo and your "douple" your goal EASY!
11-26-2012, 09:29 PM
already have a turbo RHD ae86, the rauh welt ae86 that was in the sell section
![]() 2 weeks ago I also bougt an NA LHD ae86, and that one I want it to stay NA |
11-26-2012, 09:34 PM
ditn
dat heb ik allemaal al bilstein b8 overal nieuwe rubber en kogelgewrichten en blanco gekeurd zonder opmerkingen 120drm juist wat meer power nodig[/img] |
11-26-2012, 09:59 PM
lifebeginsat8000rpm Wrote:Hi guys, Before we begin... lets make sure all the numbers are correct.... the AE86 powered by the 4AGE came in 2 different mechanical configurations 9.4 to 1 (112-115hp), and the 10 to 1 (I've never seen an "official" hp listing for this engine, but I'll assume it is 125) ALL of these numbers are measured @ the crankshaft... not @ the wheels. Assuming you have the 125bhp engine(10 to 1 compression pistons)... A properly ported head, with shaved, deshrouded chamber volume of 34cc, radius back cut valves, with a proper 3 angle valve job, Web 294 grind (their equivalent to 256 type)camshafts, adjustable timing pulleys, and a decent 4/2/1 header. The above modifications should get you comfortably into the 145-155 crank hp, or 120-130 wheel hp, running stock engine management. Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-26-2012, 10:02 PM
oldeskewltoy Wrote:lifebeginsat8000rpm Wrote:Hi guys, how can u now u have a high comp version |
11-26-2012, 10:07 PM
lifebeginsat8000rpm Wrote:how can u now u have a high comp version slug on left is 9.4 to 1, slug on right is 10 to 1 ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
How to add photos to your posts | banpei | 2 | 6,401 |
01-17-2022 10:31 PM Last Post: banpei |
A new Toyota to add to the fleet. | James | 9 | 8,159 |
03-12-2009 12:30 AM Last Post: AZNWOKZ |
HI Power AE86 | GTRJazz | 13 | 20,832 |
10-20-2007 06:48 PM Last Post: TE71corolla |
