igniter wiring for carbs
08-19-2009, 07:00 PM
hello,i want the wiring to connect the dizzy with the igniter to have spark.i have carbs on the 4age.
08-22-2009, 12:18 PM
You need to have the standard wiring from ECU to igniter to Dissy. The
igniter gets its firing signal from the ECU. If you don't want to use the
ECU to control ignition, you need an electronic dissy from a 4K or 5K
series engine... I can't remember exactly. But I'm sure you will find
the information if you search. Or check out this thread on Club4AG...
http://forums.club4ag.com/zerothread?id=359
Cheers... jondee86
08-24-2009, 09:50 PM
ok,thanks a lot.
  Tail light wiring... Mylesmck 4 1,360 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,990 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 7,383 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,791 05-18-2019 01:50 PM
Last Post: DJexor
  How to test coil with igniter DJexor 2 8,309 03-22-2018 10:01 AM
Last Post: Project D
