igniter wiring for carbs
08-19-2009, 07:00 PM
hello,i want the wiring to connect the dizzy with the igniter to have spark.i have carbs on the 4age.
08-22-2009, 12:18 PM
You need to have the standard wiring from ECU to igniter to Dissy. The
igniter gets its firing signal from the ECU. If you don't want to use the ECU to control ignition, you need an electronic dissy from a 4K or 5K series engine... I can't remember exactly. But I'm sure you will find the information if you search. Or check out this thread on Club4AG... http://forums.club4ag.com/zerothread?id=359 Cheers... jondee86 |
08-24-2009, 09:50 PM
ok,thanks a lot.
Tail light wiring... | Mylesmck | 4 | 1,375 |
02-02-2024 12:36 PM Last Post: Mylesmck |
Lambda sensor wiring | sam3007 | 10 | 4,996 |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 7,405 |
06-20-2019 11:38 AM Last Post: Lykowsky |
Some wiring help needed | DJexor | 5 | 5,798 |
How to test coil with igniter | DJexor | 2 | 8,318 |
03-22-2018 10:01 AM Last Post: Project D |
