intermitant starting problem
03-26-2006, 10:21 PM
right this is annoying me now :mad:
everynow and again the ae86 wont start i can jump start it and i can bump start it, but i cant start it by key i had the starter motor solenoids done before i put the car on the road because it wasnt starting at all, and it seemed fine for a few days, since then it just does it every few days. the electrics come on, and all is fine there, when i turn the key i here the ECU clicking but it doesnt turn over, starting to annoy me, now these problems didnt start untill i got my alarm and immobiliser fitted, does anyone have any ideas as to what the problem may be???? cheers ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-26-2006, 10:44 PM
immobiliser may nopt be working right...battery might be weak...
also check if the connector to the starter is still tight FABRICA MI DIEM, PVNC! |
03-26-2006, 10:55 PM
battery is quite small, will trace the wiring 2morrow and check that, i sometimes wonder if it is big enough
one other thing is i can sometimes leave it for a few hours and it will start again ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
03-27-2006, 09:01 AM
I've had the clicking noise before...that was the battery gone bad. I've also had it completely quiet and not even trying to start..that was an immobiliser gone bad and/or the starter signal wire come loose.
03-27-2006, 09:29 PM
Had the same problem: clicking noise and nothing. Battery gone bad, eventhough I charged it enough.
lntermittent starting | totta Crolla | 6 | 4,342 |
Starting problems 4-AGE kouki | Hanzo | 3 | 3,184 |
JDM trueno not starting. need help! | kazi | 8 | 9,606 |
20v Starting Issues | mad.matt | 10 | 12,751 |
09-24-2014 12:44 PM Last Post: pack |
starting/electrical issues | Jezza_hr | 14 | 19,889 |
12-21-2013 05:45 PM Last Post: Apsogos |
