jan speed
10-23-2005, 11:51 PM
Post: #41
jan speed
ae86 Wrote:your say that your engine is running lean on the stock pump. You have to notice that pressure in the system is a different thing from the litres of fuel your pump can handle. A stock AE86 pump can send about 125 litres per hour, a stock 4AGZE one 190 l per h and the Impreza I have 240 litres per hour. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
10-24-2005, 12:02 AM
Post: #42
jan speed
I think you must take a turbo Supra or Turbo II RX7 pump, because
they can fit easy in the tank. And for the fuel lines the engine requires 8mm input and 6mm tank return. I've not done the things above but almost there |
10-24-2005, 12:15 AM
Post: #43
jan speed
These pumps will do the trick, a Walbro HiPressure 250 lph, also!
10-24-2005, 07:12 AM
Post: #44
jan speed
it's al most a 4agze tread
Butt pressure and amount come's together. Iff the pressure is up to te rev limiter 3.1 bar, the pump can handle the needs of a stock 4agze. Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
10-25-2005, 09:05 PM
Post: #45
jan speed
Ik have fit today a fuelregelator from a 4age gen2 jap specs.
My fuelpressure is now unter boost 3.5 bar whit the stock pump!! up till te rev lim. also have my sparkplugs ngk BCPR6EP-N-8 cost: 55 euro JR Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
10-25-2005, 09:12 PM
Post: #46
jan speed | |||
10-25-2005, 09:28 PM
Post: #47
jan speed
Do you have the fuel regulator's part number?
Why does the pressure goes up with this one?? I have an aftermarket Malpassi FPR, but not using it right now... danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
10-26-2005, 07:23 PM
Post: #48
jan speed
fuel pressure regelator number is 23280-16020-0350
sparks replace Het was nodig. klepspeling was weer wel perfect Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100 Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100 KTM 950 SE ->100 3,2 sec 105 Db xt660r ->100 4,5 sec BMW 1100 GS->100 4 sec |
10-26-2005, 08:59 PM
Post: #49
jan speed
ae86 Wrote:sparks replaceSite doesn't work. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
User(s) browsing this thread: 18 Guest(s)
