just out of curiosity..? pt 2
08-27-2009, 06:08 PM
what would be the optimum wheel diameter on 4age's w/ t50 for 0-125mph i believe mines is a 22 inch diameter ....195/50/r15 ...would going with a bigger diameter would benefit or degrade?
and far as w-series trannies i know they are stronger ....but would the w50-59 gear ratios is the same, better, worse than the t-50? Reppin' the old skool....Drive Drift Dream |
08-27-2009, 09:02 PM
08-29-2009, 03:32 AM
hey thanks...i will do the numbers ... and see what i come up with???
08-29-2009, 03:59 AM
Gear Ratio my max i believe is 6400 w/ 4agze/t-50 trans/4.3 diff w 22 in. diameter tires
1st 3.59 2nd 2.02 3rd 1.38 4th 1.00 5th 0.86 @ 6000 rpms mph 25...........45...........66..........91...........106.......... 6000 rpms mph 21...........38...........55..........76...........89............ 5000 rpms mph 17...........30...........44..........61...........71............ 4000 rpms mph 13...........23...........33..........46...........53............ 3000 rpms mph 8.............15...........22..........30...........35.............2000 rpms mph 4.............8.............11..........15...........18.............1000 rpms i compared it to the w-58 trans.... here is what i got w/ same tires & diff ratio W-58 1st 3.29 2nd 1.894 3rd 1.275 4th 1.00 5th 0.783 @ 6000 rpms mph 28..........48............72.........91............117........... 6000 rpm mph 23..........40............60.........76............98............. 5000 rpm mph 19..........32............48.........61............78............. 4000 rpm mph 14..........24............36.........46............59............. 3000 rpm mph 9............16............24.........30............39............. 2000 rpm mph 5............8..............12.........15............20............. 1000 rpm see what you get???? post it up to see different tire diameter, trans, & rear diff ratios Reppin' the old skool....Drive Drift Dream |
can i just slam a oem turbo on it ? | MC_JP | 3 | 6,079 |
12-17-2014 11:04 PM Last Post: oldeskewltoy |
Mikuni carb help just wont balance | megabob | 3 | 5,173 |
01-01-2013 10:32 PM Last Post: allencr |
Just bought an 86! | GotamaHuy | 3 | 4,316 |
11-18-2010 10:38 PM Last Post: banpei |
just out of curiosity..? | ae86driftmaster | 10 | 9,420 |
08-24-2009 09:10 AM Last Post: ae86driftmaster |
just bought sum celica supras an im on a budget need tires?? | truebluegallo | 4 | 4,618 |
10-28-2008 10:21 PM Last Post: banpei |
