main ignition switch keylock
09-03-2006, 10:47 PM
i want to replace the main ignition switch-lock.
Anybody that can help me with that ? How can i take the old main switch out and replace it ? Thanks AE86 FANATIC!!! |
09-04-2006, 09:32 AM
Anybody can help me ????
AE86 FANATIC!!! |
09-04-2006, 11:07 PM
you need to put the key in the right position (see manual) and then press down on a little pin at the top and pull it out..
09-05-2006, 12:10 AM
Ιvan i looked at the manual and i haven't found a thing ...
Can you give me the page with the instructions? Thanks AE86 FANATIC!!! |
09-05-2006, 09:39 AM
AE86 FANATIC!!! |
09-05-2006, 09:59 AM
Alimonos, some cars use following trick:
Insert the ignition key. Turn it anti-clockwise to the max. Push it deeply (if this is correct technique, you will feel that you can push it ~5-6mm deep). Then turn the key clockwise to the max. Pull the entire assembly out. Try with clockwise and anticlockwise. This works with most of japan cars. |
09-05-2006, 04:31 PM
Jammie unfortunately it doesn't work with my switch
![]() Ivan ????????? Can you tell me the exact key position and where to push the pin ? ![]() Thanks AE86 FANATIC!!! |
09-05-2006, 04:58 PM
I think you need to put the key exactly vertical... the pin is at the top of the keycilinder...right behind the round metal front edge.
Ignition switch plug and wires | Blaze0010 | 3 | 625 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 14,206 |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,394 |
Peculiar headlight issue - main beam | Jezza_hr | 3 | 6,091 |
10-04-2015 09:25 PM Last Post: Jezza_hr |
4AGE 20v Ignition Lead Length | mad.matt | 3 | 6,952 |
10-01-2014 03:43 PM Last Post: mad.matt |
