main ignition switch keylock
09-03-2006, 10:47 PM
i want to replace the main ignition switch-lock.
Anybody that can help me with that ?
How can i take the old main switch out and replace it ?
Thanks
09-04-2006, 09:32 AM
Anybody can help me ????
09-04-2006, 11:07 PM
you need to put the key in the right position (see manual) and then press down on a little pin at the top and pull it out..
09-05-2006, 12:10 AM
Ιvan i looked at the manual and i haven't found a thing ...
Can you give me the page with the instructions?
Thanks
09-05-2006, 09:39 AM
09-05-2006, 09:59 AM
Alimonos, some cars use following trick:
Insert the ignition key. Turn it anti-clockwise to the max. Push it deeply (if this is correct technique, you will feel that you can push it ~5-6mm deep). Then turn the key clockwise to the max. Pull the entire assembly out.
Try with clockwise and anticlockwise. This works with most of japan cars.
09-05-2006, 04:31 PM
Jammie unfortunately it doesn't work with my switch Crying
Ivan ?????????
Can you tell me the exact key position and where to push the pin ? Dumb question
Thanks
09-05-2006, 04:58 PM
I think you need to put the key exactly vertical... the pin is at the top of the keycilinder...right behind the round metal front edge.
  Ignition switch plug and wires Blaze0010 3 591 11-25-2024 12:29 PM
Last Post: Blaze0010
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,107 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  extracted freedom ecu 16v ignition map ditn 7 9,327 08-22-2016 10:01 AM
Last Post: ditn
  Peculiar headlight issue - main beam Jezza_hr 3 6,069 10-04-2015 09:25 PM
Last Post: Jezza_hr
  4AGE 20v Ignition Lead Length mad.matt 3 6,928 10-01-2014 03:43 PM
