main ignition switch keylock
09-03-2006, 10:47 PM
i want to replace the main ignition switch-lock.
Anybody that can help me with that ? How can i take the old main switch out and replace it ? Thanks AE86 FANATIC!!! |
09-04-2006, 09:32 AM
Anybody can help me ????
AE86 FANATIC!!! |
09-04-2006, 11:07 PM
you need to put the key in the right position (see manual) and then press down on a little pin at the top and pull it out..
09-05-2006, 12:10 AM
Ιvan i looked at the manual and i haven't found a thing ...
Can you give me the page with the instructions? Thanks AE86 FANATIC!!! |
09-05-2006, 09:39 AM
AE86 FANATIC!!! |
09-05-2006, 09:59 AM
Alimonos, some cars use following trick:
Insert the ignition key. Turn it anti-clockwise to the max. Push it deeply (if this is correct technique, you will feel that you can push it ~5-6mm deep). Then turn the key clockwise to the max. Pull the entire assembly out. Try with clockwise and anticlockwise. This works with most of japan cars. |
09-05-2006, 04:31 PM
Jammie unfortunately it doesn't work with my switch
Ivan ????????? Can you tell me the exact key position and where to push the pin ? Thanks AE86 FANATIC!!! |
09-05-2006, 04:58 PM
I think you need to put the key exactly vertical... the pin is at the top of the keycilinder...right behind the round metal front edge.
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 12,983 |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,609 |
Peculiar headlight issue - main beam | Jezza_hr | 3 | 5,574 |
10-04-2015 09:25 PM Last Post: Jezza_hr |
4AGE 20v Ignition Lead Length | mad.matt | 3 | 6,460 |
10-01-2014 03:43 PM Last Post: mad.matt |
removing light switch ? (fixed) | MC_JP | 10 | 16,232 |
09-18-2014 05:16 PM Last Post: MC_JP |
