map sensor or something else?
09-16-2012, 08:00 AM
hello guys
the bad luck is chasing me! i need help.... yesterday my car was at my mechanic...i replaced some water hoses (the small ones near the thermostat and one small corner hose of the heater valve.....my mechanic drained some water fluid in a bottle from the radiator to do the work and he finished the work refill. He changed the brake hoses with perfomance hoses and new brake fluid too. I changed the starter with a reduction starter too.thats all the work that did. He had tested the car yesterday..today i took the car after 5 minutes when i press the brake to a slope to decrease the speed and stop , the engine shuts down ...i thought it was my fault but the engine cranking but not firing!i called my mechaning with check the connections everything seemed to be fine.He remove a cable from the plug...the car fired worked with 3 cyl and after he connected the 4trh... the fauld on the ecu was 2 i think is vacuum sensor - vacuum sensor circuit... the line are all new ... we removed the battery pole to eraze the fault... everything seemed fine ... i got home fine... Today at noon i got down at my car to check....cause i didnt like that she shutted down in the morning.... I turn her on and and unsteable idle (i check the faults and fault 2 again) .Not hunting but unstable...pap pap pap ... I measure the volts of the map source 4.92V (the manual says 4-6 v if i remember right. i have check the hose of the map...again ... i replace it ..the same... i removed the map.... I test it to a friend celica 4age 16v 1989 the same engine with me 2nd gen tvis.I install the map we turn her on(celica) it work fine for the moment.... any thoughts? ps ae92 corolla gti hatch sec gen tvis 4age 16v to FR 20VT |
09-16-2012, 04:36 PM
I tryied other map the same thing unstable idle(not hunting) and the thing is that the engine from cold not choking to 2000rpms eg but to 1500 max 1200rpms when hot 700rpms and feeling unstable...
on the street seems to me no loss of power no ecu faults after testing 4age 16v to FR 20VT |
09-17-2012, 07:29 AM
09-17-2012, 10:43 AM
Please block off the breather pipe that goes into the inlet plenum
from the rocker cover and report back. (the easiest way to block it off is to screw a bolt into the rubber pipe) Also see here: http://www.hachiroku.net/forums/showthread.php?t=30643 An analogue brain in a digital World |
09-17-2012, 12:05 PM
totta Crolla Wrote:Please block off the breather pipe that goes into the inlet plenum you this pipe?right? ![]() ![]() i ll do it after work and report back!thank you very much 4age 16v to FR 20VT |
09-17-2012, 02:39 PM
Apsogos, sorry I got
disconnecting that pipe will not help you I'm afraid ! An analogue brain in a digital World |
09-17-2012, 02:44 PM
09-17-2012, 04:49 PM
09-19-2012, 08:42 AM
Unstable idle and i hear , i dont know if you can hear it too a pop pop from the exhaust behind
yesterday afternoon http://youtu.be/fq0T1x1umJI yesterday night http://youtu.be/XCp_VT9gn1w Today morning http://youtu.be/R9r1PT3WQ1w 4age 16v to FR 20VT |
09-19-2012, 09:03 AM
The high idle when cold is perfectly normal.
950rpm when warm is perhaps a little high and the FSM suggests +/- 50rpm @ 850rpm An analogue brain in a digital World |
| map sensor cheating? | fdsjakl890 | 8 | 2,555 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Lambda sensor wiring | sam3007 | 10 | 7,971 |
| AFM to Map Conversion | ps13michi | 3 | 5,585 |
| Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 16,557 |
| extracted freedom ecu 16v ignition map | ditn | 7 | 11,665 |
![AEU86 AE86 - map sensor or something else? [Image: AEU86 AE86 - map sensor or something else?]](http://imageshack.us/a/img15/5245/pipeje.jpg)
![AEU86 AE86 - map sensor or something else? [Image: AEU86 AE86 - map sensor or something else?]](http://imageshack.us/a/img31/3746/4age16v.jpg)
