max overbore
10-25-2005, 04:49 AM
max overbore
whats the maximum overbore for the 4a-ge
10-25-2005, 10:34 AM
max overbore
83mm (t.e. +2mm).
10-25-2005, 10:44 AM
max overbore
I think it's different for 3-rib and 7-rib engines...the later 7-rib can be overbored the most.. dunno which values are correct though.
10-25-2005, 12:59 PM
max overbore
normal oversizes go by 0,5 or even 0,25mm
standard pistons from toyota reach a max of 82 mm but some use 83 I wouldn't go higher then 82mm or than get a 7afe if you want more torgue Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-25-2005, 01:59 PM
max overbore
thanks guys
Anyone got Max Orido's Magical Fuse? | banpei | 7 | 4,201 |
02-08-2024 11:09 AM Last Post: banpei |
Max lift on Vitz valve lifters | harkes | 9 | 11,541 |
01-02-2014 10:27 AM Last Post: Bean |
max brake disc thickness ae86 caliper+heel and toe question | ditn | 26 | 27,733 |
10-02-2012 05:00 PM Last Post: ditn |
track questions:max oil/water temp,egt and other | ditn | 7 | 8,392 |
07-06-2012 12:40 PM Last Post: ditn |
Work equip 01 max offset?? | stalker | 5 | 9,585 |
08-23-2011 03:09 AM Last Post: Lewy |
