megasquirt wiring (stock distributor)
07-26-2008, 03:54 PM
having alot of trouble with it, just finished wiring it up but i've no spark from the coil can anyone tell me how they wired theirs??
(theres a red, blue, an a white wire split in 2 inside the distrubutor an a brown wire (pin 36) from the ms to go to the ignition coil)
07-28-2008, 06:46 AM
I assume your driving the coil directly. If so, the output, pin 36 goes directly to coil.
I've seen two methods of dissy to MS depending on if you've got ESA or VAST type dissy.
ESA - I've seen signal from dissy to stock ignitor to MS. The stock ignitor conditions the signal to a square wave.
VAST - 2 opposing teeth ground off the NE signal wheel and a 12-1 decoder used.
I don't see that there should be signal difference between the VAST NE and ESA NE, so I'm going to try the grind and go on mine as I'd rather ditch the stock ignitor. There are some bits on msefi.com and write ups in the megamanual links.
Chris
08-10-2008, 03:48 PM
I used this as a basis for mine (including the modifications to ignition input and output), and it works fine. For reference my distributor is the version with 4 tooths, so not sure what you need to do if you have the 24 tooth setup.
Hope this helps
http://www.diyautotune.com/tech_articles...ta_mr2.htm
'85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21
11-24-2008, 05:38 AM
i have the same problem whit the wire of my ignitor i dont have spark
and i follow the tutorial of gon and the tutorial of diy
[Image: AEU86 AE86 - megasquirt wiring (stock distributor)]
11-25-2008, 03:28 AM
what type of distributor do you have? The solutions you've used apply only to the VAST distributor.
If you take the cap off, does the top sensor wheel have 24 teeth or 4 teeth. If it's got 4 teeth then it should work.
12-15-2008, 11:30 PM
Hello, i have mi 4AG turbo Working wit MegaSquirt 3.0 MS Extra 1
Using the Stock Distribuitor and igniter module
Vast version..
Link of the proyect: http://www.cardomain.com/ride/2975227
i can help you i have the all documentacion of my proyect
just add me to the MSN [email protected]
Cooming soon Manual "how to install MegaSquirt V 3.0 MS Extra 1 Toyota Corolla AE86 4AG Vast Ignition System"
English / Spanish
06-25-2009, 09:57 AM
I am having som trouble figuring out which color wire is what for the igniter (MAP). Black and brown I know... but what about whit, pink and yellow?
- Thanks, Niels
06-25-2009, 12:30 PM
CHACAMAN Wrote:Cooming soon Manual "how to install MegaSquirt V 3.0 MS Extra 1 Toyota Corolla AE86 4AG Vast Ignition System"
English / Spanish
Whene and were....? Yummie! Thumbs up!
SR Team
BURN THE RUBER NOT YOUR SOUL!
  Tail light wiring... Mylesmck 4 998 02-02-2024 12:36 PM
Last Post: Mylesmck
  Digital speedometer on stock dashboard FanIsHere 0 1,417 11-09-2022 01:36 PM
Last Post: FanIsHere
  Lambda sensor wiring sam3007 10 4,454 05-23-2022 10:00 PM
Last Post: The Doctor
  82mm Stock compression Pistons apardal 4 2,835 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,545 07-18-2019 03:52 PM
