mild cams... is it worth it?
01-26-2010, 02:17 PM
Hi all.
im soon gonna be swapping my Levin for a nice stock Tureno and im looking into mild tuning. with regards to cams is it worth using mild cams on a stock ecu or is it a waste of money? cheers |
01-26-2010, 04:18 PM
that realy depends how you drive it and what other mods you have (exhaust in particular) - the oem cams run out of breath a bit below 7k rpm if you want more cams are sure worth it... I'd have a look at the first two catcams.com they have a bit higher lift along with more duration and work quite good on the stock ECU as long as you modify the exhaust a little (if you still have the OEM unit, changing the bit going over the axle helps alot - as it's the most restrictive part)
AE86 ex-daily |
01-26-2010, 04:26 PM
i will be putting in an aftermarket manifold, exhaust & it already has an aftermarket filter.
what profile would you recommend? it will be used as a daily drive & for occasional track days. |
01-26-2010, 04:32 PM
catcam 7105137 was working good on robokills car - this is at the limit of the stock valvesprings and ECU - I think his was running a bit lean at the top - his bottomend was rebuild with bigger pistons though and higher CR if I'm not mistaken. iirc they are 399Euro for the set (cam wheels aren't necessary either - especialy as long as you run the stock ECU).
I myself will go for 7105148 or 9 but this needs quite some changes to the valvetrain... I intend to keep it as dailydriver too but then again I'm not too fused about economy ![]() EDITED price as I made a typo AE86 ex-daily |
01-26-2010, 04:43 PM
thanks for the info im not really wanting a great deal of power. just a little more poke. gonna be mostly working on the suspension.
01-26-2010, 07:49 PM
also a quick Q here...
what power gain is possible with those catcam 7105137 ? thats with stock ecu aftermarket filter EU exhaust manifold (no cat) and a hks 60mm catback '87 levin coupé ![]() |
01-26-2010, 08:40 PM
I do believe robokill's car was dynoed at about 133hp to the wheels. More than many silvertop 20v's that where dynoed at the same place.
With your setup you will lack the higher compression ratio and the fresh bottom-end plus some headwork of robo's setup. I'm not experienced enough with these things but I would think anywhere between 110-120 to the wheels should be possible. FABRICA MI DIEM, PVNC! |
01-26-2010, 09:58 PM
that means a power gain of approx 20-25 hp or so?
01-26-2010, 11:02 PM
PatrickAE86 Wrote:that means a power gain of approx 20-25 hp or so?that sounds about right - unfortunately there are so many aspects to it so it's realy difficult to put concret numbers down. AE86 ex-daily |
01-27-2010, 12:00 AM
Bean Bandit Wrote:catcam 7105137 was working good on robokills car - this is at the limit of the stock valvesprings and ECU - I think his was running a bit lean at the top - his bottomend was rebuild with bigger pistons though and higher CR if I'm not mistaken. iirc they are 299Euro for the set (cam wheels aren't necessary either - especialy as long as you run the stock ECU). Where can you buy these cams for 299 EUR? Is it a pair for this money? Its not so expensive.. |
Shim size for AM cams | kazi | 4 | 5,294 |
Toda Cams | Alex170984 | 7 | 8,789 |
02-11-2017 05:50 PM Last Post: Alex170984 |
20V cams - CATCAMS vs KELFORD? | Grant | 19 | 39,184 |
11-19-2015 07:45 AM Last Post: hachirokkos |
Effects of valve lift - worth it going higher? | harkes | 18 | 17,037 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
cams cams cams | megabob | 60 | 57,495 |
12-31-2013 01:19 AM Last Post: gze spec |
