mintwex 1193 pads ...too small
06-17-2007, 12:48 AM
Hi All,
Have you guys notished that teh front mintex pads are about 5mm to narrow,
So that they dont reach the egde of the disk?
there must be a great deal of brake power that is lost there?
/Skassa
"""www.turbotoys.dk"""
06-17-2007, 01:11 AM
Hey Denmark,
I would think that most brake pads leave a little bit of space but you are right that the Mintex pads are smaller, at least compared to the OEM or similar pads I have seen.
Still one has to keep in mind that 1193 wasn't made for the Hachi but made for the Diahatsu Charmant which shares alot of components with the Hachi.
1330 (if memory serves me correctly) are the proper pads for the Hachi, but they are only made in 1144 compound to order and that seems to be expensive, at least so my supplier has told me.
I am thinking about getting a 1330 normal compound pad next time I order just to see if they fit good and if they are significantly different from the 1193 pads. If business goes well for the mintex pads maybe at some point in time getting 1330's made with 1144 compound may be viable.
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 7,923 07-28-2022 10:48 PM
  Can you convert your 86 back too the original state? gh0st 7 3,129 04-25-2022 04:25 PM
Last Post: gh0st
  4age hitting gas too quick means engine stalls - what is the issue? Ryo 20 30,068 06-27-2018 11:15 PM
Last Post: Ryo
  Early tvis red top from e9 gti small or bigport? Ryo 3 7,670 04-20-2018 09:14 AM
  Problems Mintex M1155 pads Dino86 9 9,254 07-04-2017 11:22 AM
Last Post: totta Crolla
