mr.driftking in hachi. vid
11-25-2005, 07:06 PM
http://forums.club4ag.com/topic.asp?ARCH..._ID=103819
11-25-2005, 07:14 PM
It looks like shit with that spoiler Sad
[Image: AEU86 AE86 - mr.driftking in hachi.   vid]
11-25-2005, 08:17 PM
This AE86 runs a 20V Blacktop. It's totally blueprinted and has Toda Racing In 272 and Ex 288 cams with 9.8mm of lift. Pistons are also Toda Racing high compression items. ECU is "Freedom". It runs open ITB's too of course. The has a TRD close ratio gearbox (1st 3 speeds) with a TRD 2 way diff, TRD suspension and lots more. It's putting out around 200-220 bhp. Apparently this car's cost over 10,000,000 Yen to build, though it's like brand new.
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
11-25-2005, 09:17 PM
It says that it has 235 hp turbo blacktop inside now?!??!?!?!? Huh
Quote:[Image: AEU86 AE86 - mr.driftking in hachi.   vid]
New Version:
235HP Turbo spec Tomei and TRD tuned AE86 with GT wing for added traction stability.
my god! not the turbo. darn it tsuchiya!
11-25-2005, 11:55 PM
I still think there's a bigger chance that what they say in the touge showdown round 3 vid is true and that he's going 5-ag...he's even saying it himself...
11-26-2005, 02:53 AM
It already has a 5 Valve (5AGE engine). I doubt the rumour's true, as Tsuchiya would know full well a turbo would add a fair amount of weight to the front, which tends to upset the car's balance for drifting. A turbo also muffles the sound of the engine and there would be no throttle bodies to make the glorious sound this car makes, maximum revs would most likely be reduced too.
Rumours aren't always fact. Are there any pictures of the conversion?
It's possible, but unlikely, I think. Surprised to see a wing on the back of an FRP rear spoiler, as unless it's heavily braced inside it'll wobble like Pamela Anderson when running! Smile
A Tuner's Paradise
11-26-2005, 05:00 AM
its not turbocharged,still a n/a 4a-ge the specs i found some time ago are
Quote:AE111 4A-GE 5 Valves per cylinder (20V) DLI Ignition with Freeedom ECU Toda 272in/288ex 20V Camshaft (lift 9.8mm) Toda Valvetrain Toda 82mm Piston (11.3 Compression) 20V OEM Injectors 295cc TRD Custom exhaust system Aluminum 3 row radiator Power output 170hp
they upgraded teh intake cam to a 288 and remapped the ecu, the wing is to keep it stable in the fast twisties the got for the touge segment (and the do some serious speed through there) and from what i watched the 5a-ge is planned for if he gets beat again
11-26-2005, 01:29 PM
Miguel - Newera Wrote:It already has a 5 Valve (5AGE engine).
You of all people should be aware that a 5a-ge is a stroker kit consisting of a crank and conrods.. But really guys...watch touge showdown round 3 and find out for yourselves why he uses that big wing and what he plans to do with his engine.. I'm sorry to say that I couldnt find any living link to the vid yesterday...but there are torrents for the entire best motoring episode out there somewhere..
11-26-2005, 01:32 PM
Miguel - Newera Wrote:as unless it's heavily braced inside it'll wobble like Pamela Anderson when running! Smile
loool! Smile
yes i highly doubt he would put turbo in it. i dont see any good reasons. The man's old, and he wants to be takumi. so any turbos are out of the question. + i dont see how a turbo hachiroku can be faster on a downhill than nicely balanced, w/ a litlle less powerful but almost race NA engine.
11-26-2005, 01:53 PM
Quote:But really guys...watch touge showdown round 3 and find out for yourselves why he uses that big wing and what he plans to do with his engine.
i did Smile , he commented that the car felt more stable at high speeds which was what he wanted but the car was still too slow (it couldnt keep up with the miata and civic )so 5age planned if he get beaten again after sakurai does some more work on the engine
  cressida vid cannabolic 3 5,405 02-15-2012 10:05 PM
  No AE86 vid, but good stuff cannabolic 2 4,135 01-29-2010 02:50 PM
Last Post: MatthewG
  Oldskool Rally Vid Eircamae86 18 15,935 02-17-2008 11:12 PM
Last Post: nick
  First drifting vid 86drift 3 5,354 10-19-2007 12:05 PM
Last Post: 86drift
  2006 AE86 Australian Annual meet up VID matt mead 4 5,320 03-18-2007 09:02 PM
Last Post: a112
