my gze project video
08-14-2010, 11:19 AM
Reppin' the old skool....Drive Drift Dream ![]() ![]() |
08-14-2010, 06:31 PM
beautiful...!
What paint did u use on ur car for the black? I'm actually thinkin of going for ur color.. Cheated on my いたずらな女の子 and now I can't get enough of her.. |
08-14-2010, 09:22 PM
thanks heshan...
i repainted the engine bay...i forgot the name of the brand....it a plain black ..no metallic or pearls in it.. Reppin' the old skool....Drive Drift Dream ![]() ![]() |
08-14-2010, 09:45 PM
wow for a normal black paint the sheen's quite good..
I just did a Gze conversion myself.. Want to paint it as well and looking around for a good color.. how much does ur car make at the wheels with ur Gze? any mods u've done? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
08-14-2010, 10:58 PM
the paint was solid when i purchased the car....just did some serious buffing i used the 3m product the bodyshops used they sell for $40 a bottle
when i 1st purchased it ..i got 143whp i did more work to it before the motor went...im guessing 160-80 whp......i yet to start the new motor ...i should crack well over 200whp..i changed lots of the internals, and engine balancing here is the parts list as of now... newly added: tomei 2way diff T3 Traction brackets T3 4links T3 rca T3 panhard T3 tension rods Richmond gears Ring & Pinion 4.3 seibon c/f doors seibon c/f hatch carbon 8 c/f wing cusco safety 21 ...6 point roll cage new 2 1/4 weather strips new hatch weathet strip new hood latch clip zaklee clear cam cover NST 4agze s/c pulley set NST master brake stopper Dmax rear 1/4 panels 45mm Origin lab 30 mm over fenders this is list what i have & bought i for it from what i remember... used cusco 175mm pulley thanks smallport4ag new cxr front mount intercooler new hks 256 in/ex 8.1 lift new hks cam gears new hks timing belt new 20 over gze pistons 8:9 new federal crank bearings new acl connecting rod bearings new toyota oil pump new toyota complete rebuild kit new arp fly wheel bolts new arp head bolts new arp connecting rod bolts new Exedy stage II clutch & act stage II both are sprung 6 pucks new steal braided clutch line new AEM eugo wide band new toyota water pump new koyo radiator new tomei fuel pressure regulator w/fuel line adaptor new trd engine mount new trd f/r anti sway bars new cusco tranny mount new cusco f/r strut bars new greddy e manage new greddy tic cat back new greddy type s coilovers new greddy big brake kit 6 mini piston new greddy oil pressure gauge new greddy boost gauge new magnaflow catalytic new Dmax carbon fiber hood new 13lbs drive shaft the motor: sent injectors to be cleaned and calibrated...now pushing 388cc new fuel pump ported & polished port matched intake manifold new valve seats new over sized valves crank,piston,connecting rod balancing flywheel cut ugraded the starter to a 1.6 kw new MR-2 toyota altenator other parts: new rear koyo axle bearing new front moog bearing in/out new driver side door hinges Reppin' the old skool....Drive Drift Dream ![]() ![]() |
Newera's AE86 Project - Video of 1st Trackday, Nikko, | Miguel - Newera | 4 | 5,517 |
06-29-2006 01:43 PM Last Post: JamesAE86 |
