oem head gasket thickness?
05-12-2009, 12:30 PM
hi there.i need to change my haed gasket but what was the oem head gasket thickness?? thnx
05-12-2009, 06:47 PM
1.00 mm
SR Team
BURN THE RUBER NOT YOUR SOUL!
05-12-2009, 10:26 PM
thnx
05-16-2009, 10:17 PM
wrong, 1.2mm Wink
Bas alors boomex tu dis des bĂȘtises ?! :lol:
(boomex is one of my friends Wink)
05-17-2009, 01:03 AM
1.2mm before installation ... once you tighten down the head bolts it goes to 1.0mm....
or when you take a used one out of the engine its 1.0mm
05-22-2009, 10:46 PM
thnx again Smile
  Oil leak (maybe a cylinder head gasket?) max_ae86 15 17,345 11-30-2013 03:59 AM
Last Post: jondee86
  4AGE Heat Shielding Intake Gasket asyrigos 11 24,062 04-01-2013 10:58 AM
Last Post: asyrigos
  max brake disc thickness ae86 caliper+heel and toe question ditn 26 26,944 10-02-2012 05:00 PM
Last Post: ditn
  OEM sway bar thickness ?? T_AE86 5 11,881 08-07-2011 04:05 PM
Last Post: Hachi
  Doing a 7AGE build, gasket question Snejk 9 14,390 07-15-2010 12:42 PM
Last Post: PetzK
