oem head gasket thickness?
05-12-2009, 12:30 PM
hi there.i need to change my haed gasket but what was the oem head gasket thickness?? thnx
05-12-2009, 06:47 PM
1.00 mm
SR Team BURN THE RUBER NOT YOUR SOUL! |
05-12-2009, 10:26 PM
thnx
05-16-2009, 10:17 PM
wrong, 1.2mm
Bas alors boomex tu dis des bĂȘtises ?! :lol: (boomex is one of my friends ) |
05-17-2009, 01:03 AM
1.2mm before installation ... once you tighten down the head bolts it goes to 1.0mm....
or when you take a used one out of the engine its 1.0mm |
05-22-2009, 10:46 PM
thnx again
Oil leak (maybe a cylinder head gasket?) | max_ae86 | 15 | 17,343 |
11-30-2013 03:59 AM Last Post: jondee86 |
4AGE Heat Shielding Intake Gasket | asyrigos | 11 | 24,061 |
04-01-2013 10:58 AM Last Post: asyrigos |
max brake disc thickness ae86 caliper+heel and toe question | ditn | 26 | 26,943 |
10-02-2012 05:00 PM Last Post: ditn |
OEM sway bar thickness ?? | T_AE86 | 5 | 11,881 |
08-07-2011 04:05 PM Last Post: Hachi |
Doing a 7AGE build, gasket question | Snejk | 9 | 14,390 |
07-15-2010 12:42 PM Last Post: PetzK |
