oil catch can/ suspension question
04-22-2011, 11:42 PM
I'm curios about oil catch can also.
My 4AGE also looses lot's of oil on hard driving.
It ain't that much as fax0815 engine does, but i believe it's to much.
What about catch can, and two vented camshaft covers ?
Also, what should vent have to prevent direct oil spray ?
I have my head disassembled at the moment, would appreciate advice what to do with vents. Could weld different vents if needed Smile.
Thanks
04-23-2011, 01:31 AM
@ fax0815... yes, that is the style. Oil collected in the expansion chamber
will drain back to the engine on the overrun.
@ Uzelac... Many standard catch cans have two pipe connections on the
side, and one vent out the top (to atmosphere). You could try using two
right hand cam covers to connect to the two pipes on the catch can.
Standard cam covers have an elaborate baffle over the exit of the vent
tube, to reduce oil carryover. Blowby does increase with speed and wear.
So perhaps a leakdown test would show it's time for new rings ?
Cheers... jondee86
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,162 03-05-2023 09:34 PM
  Can you convert your 86 back too the original state? gh0st 7 2,886 04-25-2022 04:25 PM
Last Post: gh0st
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 7,973 12-19-2021 11:58 PM
Last Post: gh0st
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,422 09-08-2021 12:48 PM
Last Post: Ryo
  can i just slam a oem turbo on it ? MC_JP 3 6,037 12-17-2014 11:04 PM
