oil cooler?
10-13-2013, 09:39 PM
oil cooler?
hello i make a swap...ke 70 with 4age 16v.it is important to put the oil cooler?the use they will be for every day jobs...nothing else...
10-14-2013, 07:40 AM
oil cooler?
If you are talking about the Toyota factory oil cooler with a return hose
into the oil pan, then not important. The factory cooler is a by-pass type, and oil is only sent to the cooler when the rpm's (and oil pressure) are high. At lower rpm's the spring- loaded bypass valve is closed, and no oil is sent to the cooler. So for normal around town driving the cooler is just extra weight. Cheers... jondee86 |
10-14-2013, 03:32 PM
oil cooler?
Before I rebuilt my engine I was running a corolla sump and obviously couldn't connect up my aw11 oil cooler arrangement and never had any issues. Have since bought an aw11 sump with the oulet.
10-14-2013, 07:36 PM
oil cooler?
yes i am talking for the toyota factory oil cooler....
thanks guys!!!! |
10-20-2013, 07:43 AM
oil cooler?
jondee86 Wrote:If you are talking about the Toyota factory oil cooler with a return hose i have replaced my oem oil cooler with a new better one (handmade) , i want to ask if you know at how many rpms the valve opens? thank you 4age 16v to FR 20VT |
10-27-2013, 08:30 AM
oil cooler?
Apsogos Wrote:jondee86 Wrote:If you are talking about the Toyota factory oil cooler with a return hose and a second question that i have is if anyone know how much pressure from 0 oil psi or bar shows the climax on the oem gauge (ae92)
| Mocal oil cooler & sandwitch plate ordered | Gtsi-R | 48 | 65,522 |
| Oil cooler | totta Crolla | 0 | 2,264 |
| Oil cooler kit | izanagi | 7 | 10,418 |
| Permanent oil cooler vs thermostat | Lt86 | 19 | 24,800 |
03-28-2015 06:54 PM Last Post: Lt86 |
| trans oil, lsd oil change | Apolan | 9 | 20,136 |
![AEU86 AE86 - oil cooler? [Image: AEU86 AE86 - oil cooler?]](http://img402.imageshack.us/img402/369/oilpressuregauge.jpg)
