oil cooler?
10-13-2013, 09:39 PM
oil cooler?
hello i make a swap...ke 70 with 4age 16v.it is important to put the oil cooler?the use they will be for every day jobs...nothing else...
10-14-2013, 07:40 AM
oil cooler?
If you are talking about the Toyota factory oil cooler with a return hose
into the oil pan, then not important.
The factory cooler is a by-pass type, and oil is only sent to the cooler
when the rpm's (and oil pressure) are high. At lower rpm's the spring-
loaded bypass valve is closed, and no oil is sent to the cooler. So for
normal around town driving the cooler is just extra weight.
Cheers... jondee86
10-14-2013, 03:32 PM
oil cooler?
Before I rebuilt my engine I was running a corolla sump and obviously couldn't connect up my aw11 oil cooler arrangement and never had any issues. Have since bought an aw11 sump with the oulet.
10-14-2013, 07:36 PM
oil cooler?
yes i am talking for the toyota factory oil cooler....
thanks guys!!!!
10-20-2013, 07:43 AM
oil cooler?
jondee86 Wrote:If you are talking about the Toyota factory oil cooler with a return hose
Cheers... jondee86
i have replaced my oem oil cooler with a new better one (handmade) , i want to ask if you know at how many rpms the valve opens? thank you
4age 16v to FR 20VT
10-27-2013, 08:30 AM
oil cooler?
Cheers... jondee86
and a second question that i have is if anyone know how much pressure from 0 oil psi or bar shows the climax on the oem gauge (ae92)
[Image: AEU86 AE86 - oil cooler?]
4age 16v to FR 20VT
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 54,611 11-18-2022 02:19 PM
Last Post: FanIsHere
  Oil cooler totta Crolla 0 1,523 07-25-2021 03:25 PM
Last Post: totta Crolla
  Oil cooler kit izanagi 7 8,529 09-20-2016 11:13 AM
Last Post: harkes
  Permanent oil cooler vs thermostat Lt86 19 20,531 03-28-2015 06:54 PM
Last Post: Lt86
  trans oil, lsd oil change Apolan 9 16,881 10-01-2014 03:57 PM
