oil pressure high
09-27-2013, 07:54 PM
No, not all stock senders are pressure switches. The switch is much smaller than a proper pressure sensor.
@Pack: that doesnt look quite right to me, the second contact is welded to the body, so I doubt it can switch any signal to ground, because it is permanently connected to ground via the engine block which it is screwed into. Look for something like this: http://www.ebay.de/itm/Oldruck-Geber-VDO...1e8037d328 Ebay germany is a good place to find stuff that wont kill you in shipping.. as long as they are willing to shop internationally... look for 'oeldruckgeber + warnkontakt'. Just make sure the thread pitch is correct for a 4age, and the resistance + pressure range is correct for your gauge. You cant just combine any sensor with any gauge. FABRICA MI DIEM, PVNC! |
Messages In This Thread |
oil pressure high - kawo - 09-14-2013, 04:22 AM
[] - Ivan141 - 09-27-2013 07:54 PM
High-beam warning lamp | Mylesmck | 4 | 1,575 |
07-21-2023 07:44 AM Last Post: banpei |
Engine stress at high speeds | gh0st | 6 | 2,668 |
08-30-2022 07:11 PM Last Post: Power_uP |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 22,226 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,237 |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 34,637 |
08-21-2016 04:51 PM Last Post: ray |
