oil pressure high
09-28-2013, 10:13 PM
Pack, I just looked up the first sensor of the type I meant as an example.
You should really look up the correct thread pitch for your application and make sure you order a sensor with that thread type.
I'm guessing most of the regular VDO gauges will work with a sensor like this as long as the range is identical (so not 0-5 gauge with a 0-10 sensor or vice versa).
http://www.ebay.de/itm/VDO-Oldruckanzeig...3cd65e49b5
I might add that 0-5 bar would probably be an adequate sensor range to go for on most car engines.
Messages In This Thread
oil pressure high - kawo - 09-14-2013, 04:22 AM
[] - jondee86 - 09-15-2013, 12:26 AM
[] - allencr - 09-15-2013, 01:23 AM
[] - kawo - 09-27-2013, 05:22 AM
[] - jondee86 - 09-27-2013, 06:31 AM
[] - Rascal21 - 09-27-2013, 01:32 PM
[] - pack - 09-27-2013, 03:22 PM
[] - Ivan141 - 09-27-2013, 05:35 PM
[] - pack - 09-27-2013, 06:05 PM
[] - kawo - 09-27-2013, 06:57 PM
[] - Ivan141 - 09-27-2013, 07:54 PM
[] - jondee86 - 09-27-2013, 11:48 PM
[] - pack - 09-28-2013, 01:47 AM
[] - Ivan141 - 09-28-2013, 12:32 PM
[] - pack - 09-28-2013, 01:41 PM
[] - Ivan141 - 09-28-2013 10:13 PM
[] - allencr - 09-29-2013, 12:06 PM
  High-beam warning lamp Mylesmck 4 1,575 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 2,668 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 22,226 12-31-2020 06:39 AM
Last Post: chenfon
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,237 08-19-2018 12:08 PM
Last Post: AlexKTM
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 34,637 08-21-2016 04:51 PM
Last Post: ray
