ok,tough questions
01-09-2005, 04:55 PM
ok,tough questions
As some of you may know, my EightSix has a 4agze on it. Respect! http://www.aeu86.org/download.php?id=897
1st Question:
The car has no thermostat n i d like to install one. I was told I could use one from a Renault 5.
In this forum I was told I could use a LADA one.
http://www.aeu86.org/download.php?id=895
I need a radiator hose with a thermostat in it, fitting both engine and radiator...
Any ideas????????????????
2nd Question:
A friend of mine has a spare 4age Oil cooler radiator.
Can this in some way be used with the 4agZe?
Anyone doone this???
[Image: AEU86 AE86 - ok,tough questions] http://www.jdmbits.com
01-09-2005, 06:04 PM
ok,tough questions
1st...post some pics of your engine and waterpump, if you have the rear waterpump housing of an original ae86 4age (which is not unlikely) then you can simply put a thermostat in there, otherwise just find an inline thermostat housing that fits your enginebay and place it in the watertube leading from radiator to waterpump. Be carefull though, the stock cooling system has a bypass for coolant flow around the thermostat, I think you'll need to have such a bypass in place if you want to use a thermostat.
AE92 and AE82 use remote thermostat housings, they are clunky but have connections for water in/out and bypass.
2nd
To use an oil cooler you need to have the sandwich plate that sits under the oilfilter, it has a nozzle on the underside, where the oil feed to the cooler comes from. I think you could probably take this from any 4age that has one. After that all you need to do is weld a nozzle for the oil return line somewhere high in the oilpan.
01-10-2005, 12:03 PM
ok,tough questions
About the 2nd Question:
Brand new 4AF(E) oil sandwich plate from the dealer is just ~30EU and can be used as bolt-on setup !
The 4AGE one is ~95EU !
01-10-2005, 12:44 PM
ok,tough questions
oil cooler .... check temp before you place it
thermostate just place it at original location costs around 20 eruo's complete with fitting
01-10-2005, 05:33 PM
ok,tough questions
I took a look at the pictures...it's not very likely that the rwd waterpump is still in place since the supercharger sits in the way.
Correct me if I'm wrong but the bottom water hose comes out the back of the waterpump between the engine and S/C right?
I still think that installing the plumbing of an ae92 4age would be the easiest solution since that probably fits on a 4agze as well. only trouble is getting the water lines to the radiator..
01-10-2005, 06:21 PM
ok,tough questions
oh, boy.
Thats too much work..
Nevermind, f*ck it, I'll keep workin 1.400 @ idle
01-10-2005, 07:17 PM
ok,tough questions
You could try closing the air bypass or putting a restrictor in, it's the big hole in the bottom of the throttle body. That would stop the intake from automatically taking more air at lower temps. Running to low temperatures leads to high fuel consumtion though, so it would be nice to have a thermostat in winter.
01-10-2005, 07:33 PM
ok,tough questions
I know that about the fuel consumption.
That's my problem...
Tested car consumption, between 13 litres/100km (lowest
to an RX-8 equivalent 20,5 litres per 100 km!!!!!!!!!!
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 3,015 05-26-2024 07:40 PM
Last Post: totta Crolla
  Windscreen stoopid(?) questions.... Mylesmck 7 1,549 04-30-2024 09:46 PM
Last Post: Mylesmck
  Brake Bias Questions mad.matt 10 11,937 01-03-2019 04:54 AM
  wider rear axle,track width,suspension questions ditn 6 9,274 10-18-2016 11:50 AM
Last Post: fantapants
  Suspension questions leon205gti 17 15,489 04-30-2016 09:26 PM
Last Post: krullibull
