oldskull's Levin
06-04-2007, 05:20 PM
Post: #191
oldskull's Levin
Yes you got it, its not much but there is something strange with my car. it is more than 1mm and since i put koni yellow under my car and it is more lower than tokico blues or OEM shocks. anyway I think I need to check the align of my tyres too. Yeah I will answer your pm
06-12-2007, 09:29 PM
Post: #192
oldskull's Levin
Finally I installed T3 adjustment panhard rod yesterday. But with some stupid happened after everything installed then I lowered the jack and I went under the car to adjust them I found out that I cant adjust it at all because one of the nuts are fastened. So I am fed up I just stopped and continued today. Right know my rear wheels are centered
So only one more problem (left front suspension is lowered than the right side) need to be resolve. I will try to solve them after bushing, RCA and camber plates install. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
06-12-2007, 09:55 PM
Post: #193
oldskull's Levin
Nice work - even though you had to try twice
Your car is looking just great! I would go just a bit lower and the stance would be perfect Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
06-12-2007, 10:35 PM
Post: #194
oldskull's Levin
Thanks Jan.
Yes I like to go a bit more lower but I need to take a good decision. About few hundred meter from where I live there is a small village if I want to gone to Amsterdam, I should drive trough there even almost to anywhere I must drive trough that village first and I you drive to there my car will shaking like hell with my current suspensions. So if my suspensions too hard I will easily get crazy about it and get my back hurt. I am quite older now So I think it will take sometime to get my car lower only if some nice offer come around , so first saving some cent to get rust-protections and new paint 1985 AE86 (ハチロク) Levin - Summer time daily driver |
06-12-2007, 10:53 PM
Post: #195
oldskull's Levin
Ohh I see I know about getting older too: When I drove my 86 every day I didn't think it was THAT rough, but after driving something a bit more comfortable for two years...Well lets just say that I've gotten older I might have to buy some adj dampers for the front end - that would make it a lot smoother. There is quite a difference when I adjust the rear dampers
06-12-2007, 10:56 PM
Post: #196
oldskull's Levin
yeah good idea about adjustment dampers for front end I am thinking buying the hole set with easily adjustment without taking the struts apart (like koni)
06-12-2007, 11:03 PM
Post: #197
oldskull's Levin
It has to be done without taking anything apart! I'm running TRD and I'm sticking with them for sure! And they are only a bit more expensive than yellow Konis
06-13-2007, 01:00 AM
Post: #198
oldskull's Levin
grandapas.
06-13-2007, 08:13 AM
Post: #199
oldskull's Levin
oldskull Wrote:About few hundred meter from where I live there is a small village if I want to gone to Amsterdam, I should drive trough there even almost to anywhere I must drive trough that village first and I you drive to there my car will shaking like hell with my current suspensions. So if my suspensions too hard I will easily get crazy about it and get my back hurt. I am quite older nowI assume you mean the route right through the forest and next to the moor (heide). If you're talking about speedbumps: then you have to be careful not to drive to quick over them, if you're talking about the stone-roads you better keep the car going and push it hard. > Atleast, that's what I found out with the previous springs under my car. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-13-2007, 09:11 AM
Post: #200
oldskull's Levin
Apolan Wrote:grandapas.HEYHEYHEY! :wink: Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
