'orrid vibration
01-29-2009, 11:42 PM
'orrid vibration
coming from drive line. Between 5000 and 6000rpm approx. and more violent in 5th gear for some reason.
I have put the car on stands, removed the wheels calipers and discs and then run the car through the gears. Could it be the flywheel ? I have recently fitted a lightened one. Gearbox maybe ? The vibration is bad enough to ensure that on the track I don't go beyond 75mph as the car feels just awful. The rear wheel bearings are fine and a new propshaft centre bearing was fitted 3000 miles ago together with a new modified (to suit Ford gearbox) and balanced propshaft. Thanks for any help. TC An analogue brain in a digital World |
01-30-2009, 07:12 PM
'orrid vibration
clutch out of balance???
input shaft bearings? Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-30-2009, 09:04 PM
'orrid vibration
I think I have an answer and you won't believe it
![]() Whilst inspecting the propshaft centre bearing I noticed some fairly heavy denting on the exhaust, it is hitting the propshaft middle joint flange ![]() ![]() Or it's gearbox related and probably the tailshaft housing bush...... ![]() Anyone know how much lateral movement there can be in the propshaft centre bearing bush ? Thanks, TC An analogue brain in a digital World |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,791 |
11-29-2014 12:27 AM Last Post: dinkers542 |
driveline vibration TE71 | teun | 23 | 23,917 |
03-07-2014 10:36 PM Last Post: totta Crolla |
noise and some vibration | gtsr54321 | 2 | 3,815 |
02-01-2009 07:50 AM Last Post: jondee86 |
Engine/Drivetrain Vibration Issues | apardal | 19 | 20,356 |
09-14-2007 03:12 AM Last Post: jondee86 |
Vibration/Shudder In steering over approx 100kph | Ian.G | 8 | 7,284 |
05-10-2005 02:20 PM Last Post: jamiemirror |
